lotustechie
- Jun 3, 2020
I was starting to run out of space, so I decided to upgrade my HDDs. Before I had 8 4TB drives. I installed new 12TB drives one at a time until they were resilvered and now I am getting degraded errors on 3 of the 4 new drives. I am currently running a scrub to see if that will resolve the errors. I ran a zpool status and got the following information:
root@airiam[/]# zpool status -v pool: Data state: DEGRADED status: One or more devices has experienced an error resulting in data corruption. Applications may be affected. action: Restore the file in question if possible. Otherwise restore the entire pool from backup. see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A scan: scrub in progress since Fri Oct 30 13:58:07 2020 3.00T scanned at 5.82G/s, 264G issued at 511M/s, 26.3T total 0B repaired, 0.98% done, 14:49:53 to go config: NAME STATE READ WRITE CKSUM Data DEGRADED 0 0 0 raidz1-0 ONLINE 0 0 0 gptid/7be29992-a674-11ea-a1ae-a8a159238732 ONLINE 0 0 0 gptid/81431cc2-a674-11ea-a1ae-a8a159238732 ONLINE 0 0 0 gptid/845353ab-a674-11ea-a1ae-a8a159238732 ONLINE 0 0 0 gptid/85f57ef6-a674-11ea-a1ae-a8a159238732 ONLINE 0 0 0 raidz1-1 DEGRADED 0 0 0 gptid/465eafc7-1a4f-11eb-a086-a8a159238732 DEGRADED 0 0 333 too many errors gptid/9772beeb-1a9c-11eb-be62-a8a159238732 ONLINE 0 0 724 gptid/b48bd088-1995-11eb-b3e4-a8a159238732 DEGRADED 0 0 312 too many errors gptid/b00d0686-1935-11eb-92a3-a8a159238732 DEGRADED 0 0 302 too many errors errors: Permanent errors have been detected in the following files: Data/iocage/jails/LT-PMS01/root@ioc_update_11.3-RELEASE-p11_2020-09-24_12-09-16:/Plex Media Server/Metadata/Movies/0/848f6d7b66011d0e9f96767834689bfa8e7b05d.bundle/Contents/_stored/posters/com.plexapp.agents.imdb_456e3b4ece52f98fdff17bcd3be45fd3aa7b6e9e /mnt/Data/Media/Movies/The Assistant (2020)/The Assistant (2020).mp4 /mnt/Data/Media/Movies/House Party 2 (1991)/House Party 2 (1991).mp4 /mnt/Data/Media/Movies/Tape (2020)/Tape (2020).mp4 /var/db/system/samba4/winbindd_cache.tdb /var/db/system/samba4/registry.tdb /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/auth.log /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/console.log /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/daemon.log /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/middlewared.log /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/utx.log /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/samba4/log.winbindd /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/messages /var/db/system/syslog-445a1355f3314ba4946bd845d9821e43/log/debug.log /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-dbuf_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da2.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da7/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da3.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da0.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da1.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da3.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-download-11.3-RELEASE/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da1.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da2.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da3.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.3-RELEASE/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da0.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da1.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da2.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da3.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.3-RELEASE-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.3-RELEASE-root/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/interface-bridge0/if_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-LT-PMS01/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/interface-re0/if_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-LT-PMS01-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/interface-vnet0.1/if_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/interface-vnet0.1/if_packets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/load/load.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/memory/memory-active.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/memory/memory-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/memory/memory-laundry.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/memory/memory-wired.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da5/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da5/disk_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da5/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da6/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da6/disk_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da4.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da4.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da4.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da4.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da5.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da5.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da5.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da5.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_busy_percent-da5.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da7/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-average/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/processes/ps_state-running.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da7/disk_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/processes/ps_state-sleeping.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da7/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-average/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_queue-da6.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da6.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-sum/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/processes/ps_state-zombies.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-sum/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_bw-da6.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-sum/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da6.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-sum/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/aggregation-cpu-sum/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/rrdcached/gauge-tree_nodes.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-0/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops-da7.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/rrdcached/operations-receive-update.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_ops_rwd-da7.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-0/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/rrdcached/operations-write-data_sets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-0/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/rrdcached/operations-write-updates.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_busy_percent-da7.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/swap/swap-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-1/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-1/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/uptime/uptime.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_eviction-eligible.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-10/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_eviction-ineligible.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-10/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_operation-deleted.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disktemp-da7/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_ratio-arc.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-11/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-demand_data-miss.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-11/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-demand_metadata-hit.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-radarr/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-11/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-mfu-hit.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-radarr-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-2/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-mfu_ghost-hit.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-mru-hit.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-OpenVPN/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-2/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-prefetch_data-miss.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-3/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-prefetch_metadata-hit.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-3/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_result-prefetch_metadata-miss.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-3/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails-OpenVPN-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-3/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-anon_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-3/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-arc.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-4/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-c.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-4/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-c_max.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-4/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-c_min.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-4/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-4/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-5/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-mfu_ghost_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-5/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-5/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-mru_ghost_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-5/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-mru_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-5/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-6/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-p.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-6/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/hash_collisions.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da6/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-6/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-6/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-6/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/mutex_operations-miss.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-7/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_arc-hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-7/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-7/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-download-11.4-RELEASE/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-7/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_arc-misses.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-7/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_data-demand_data_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.4-RELEASE/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-8/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-8/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-8/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.4-RELEASE/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-8/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_metadata-demand_metadata_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-11.4-RELEASE-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-8/cpu-user.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-9/cpu-idle.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_metadata-prefetch_metadata_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-9/cpu-interrupt.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-9/cpu-nice.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_mu-mfu_ghost_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cpu-9/cpu-system.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/arcstat_ratio_mu-mru_ghost_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-0/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-10/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-2/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-3/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-4/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_arcmeta-arc_meta_used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-6/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-7/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_counts-deleted.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-8/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/cputemp-9/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_cp-c_max.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_cp-c_min.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_data_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_data_misses.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_evict-evict_skip.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_hash-hash_collisions.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_hits_misses-hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_hits_misses-misses.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-dnode_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc/cache_size-bonus_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da0/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da1/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da4/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da5/pending_operations.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_mru-mfu_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_mru-mru_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da0/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_prefetch-prefetch_data_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da0/disk_ops.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_prefetch-prefetch_metadata_hits.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da0/disk_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_prefetch-prefetch_metadata_misses.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da1/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_size-data_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_size-hdr_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da1/disk_ops.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_size-other_size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-download-12.1-RELEASE/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/zfs_arc_v2/gauge_arcstats_raw_size-size.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da2/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da2/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da2/disk_ops.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da3/disk_io_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da3/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da3/disk_ops.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-releases-12.1-RELEASE-root/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-da3/disk_time.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disk-nvd0/disk_octets.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/disktemp-da2/temperature.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-download/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_busy_percent-da0.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_busy_percent-da1.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-images/df_complex-used.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_busy_percent-nvd0.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/df-mnt-Data-iocage-jails/df_complex-free.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_bw-da0.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_bw-da1.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_bw-da2.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_bw-da3.rrd /var/db/system/rrd-445a1355f3314ba4946bd845d9821e43/localhost/geom_stat/geom_latency-da0.rrd Data/iocage:<0x0> /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/3c/7759a20d368a7d3f8c2e2568844b41aa87a28c /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/fc/a061815626506dd42bfe8f33ec37d15681d5c0 /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/ce/69cfc3c965e1609159898958ca11fb1b3270be /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/8f/4bf8c44731af61b89012ba044b63d73effcc8c /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/4e/160df40d0044b64af2558529d313856703a1d7 /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/objects/9b/3c4e5e75045333a07de6d5c3595d058b68b447 /mnt/Data/iocage/.plugins/github_com_freenas_iocage-ix-plugins_git/.git/index /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/INDEX /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/icons/rslsync.png /mnt/Data/iocage/.plugins/github_com_ix-plugin-hub_iocage-plugin-index_git/.git/logs/refs/remotes/origin/master /mnt/Data/iocage/jails/LT-PMS01/config.json Data/iocage/jails/LT-PMS01/root:<0x0> /mnt/Data/iocage/jails/LT-PMS01/root/var/log/messages /mnt/Data/iocage/jails/LT-PMS01/root/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-wal /mnt/Data/iocage/jails/LT-PMS01/root/Plex Media Server/Plug-in Support/Databases/com.plexapp.plugins.library.db-shm pool: freenas-boot state: ONLINE status: Some supported features are not enabled on the pool. The pool can still be used, but some features are unavailable. action: Enable all features using 'zpool upgrade'. Once this is done, the pool may no longer be accessible by software that does not support the features. See zpool-features(5) for details. scan: scrub repaired 0B in 00:00:10 with 0 errors on Thu Oct 29 03:45:10 2020 config: NAME STATE READ WRITE CKSUM freenas-boot ONLINE 0 0 0 nvd0p2 ONLINE 0 0 0 errors: No known data errors
