evillone
- May 17, 2014
Greetings All !
This is a first for me, after getting alerts on the pool i tried running a scrub on the pool and it identified errors with some files,
just wondering if there is any way to correct this, or if i have to start fresh with the pool
any comments are appreciated
thank you !
pool: E
state: ONLINE
corruption. Applications may be affected.
action: Restore the file in question if possible. Otherwise restore the
entire pool from backup.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-8A
scan: scrub repaired 644K in 07:15:05 with 13 errors on Thu Aug 24 05:08:59 2023
NAME STATE READ WRITE CKSUM
E ONLINE 0 0 0
raidz1-0 ONLINE 0 0 0
gptid/a9b0b60f-c3c9-11ea-b7ce-6805ca32cdb3 ONLINE 0 090
gptid/68f0342d-4cf1-11e5-8f38-6805ca32cdb3 ONLINE 0 090
gptid/7053cea4-be45-11e5-9c31-6805ca32cdb3 ONLINE 0 092
gptid/6a114719-4cf1-11e5-8f38-6805ca32cdb3 ONLINE 0 0 155
gptid/6a64799b-4cf1-11e5-8f38-6805ca32cdb3 ONLINE 0 092
gptid/7bd17363-1963-11e6-9ccc-6805ca32cdb3 ONLINE 0 097
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/cpu-11/cpu-idle.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/cpu-11/cpu-interrupt.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/zfs_arc_v2/gauge_arcstats_raw_hash-hash_collisions.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_data_misses.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/geom_stat/geom_ops-ada4.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/zfs_arc_v2/gauge_arcstats_raw_demand-demand_data_hits.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/geom_stat/geom_ops-ada2.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/geom_stat/geom_busy_percent-ada2.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/geom_stat/geom_latency-ada5.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/cpu-4/cpu-system.rrd
/var/db/system/rrd-f1ae6c68bbe041c7bb38cadeec088781/localhost/cpu-4/cpu-interrupt.rrd
system.rrd
pool: boot-pool
state: ONLINE
thank you !
pool: E
state: ONLINE
E ONLINE 0 0 0
system.rrd
pool: boot-pool
state: ONLINE
