FreeNAS 11.2U5 kernel panics
ziphe
I've been having kernel panics in 11.2U5, but it was also happening on earlier versions. I have the /data/crash dumps, what can I do with this information to help troubleshoot this issue? It happens at around 13-14 days of uptime, and it's a pretty busy box.
More info:
Fatal trap 12: page fault while in kernel mode
cpuid = 4; apic id = 04
fault virtual address = 0x9b
fault code = supervisor read data, page not present
instruction pointer = 0x20:0xffffffff803f3714
stack pointer = 0x28:0xfffffe2016267a60
frame pointer = 0x28:0xfffffe2016267a90
code segment = base 0x0, limit 0xfffff, type 0x1b
= DPL 0, pres 1, long 1, def32 0, gran 1
processor eflags = interrupt enabled, resume, IOPL = 0
current process = 49134 (rclone)
Thanks in advance
Meyers
I've been experiencing unexpected reboots for months. This post lead me to check out /data/crash and sure enough:
cpuid = 4; apic id = 08
fault virtual address   = 0x3b8
instruction pointer     = 0x20:0xffffffff80ab391d
stack pointer           = 0x28:0xfffffe08615ad1b0
frame pointer           = 0x28:0xfffffe08615ad250
current process         = 6505 (qbittorrent-nox)
BTW you'll want to post all your relevant hardware and software details if you want any help. See what I've put in my sig for an example.
Meyers
Here is my ongoing ticket.
ziphe
I am not 100% certain, but my gut feeling is that high load inside a jail is triggering the panic. I've moved the rclone jobs to a native FreeBSD vm on a different host at this point, so if my theory is correct my kernel panics should go away. I have 5 kernel panics in a row (10-14 days apart) all showing the same trap 12 same supervisor read not present error, and always the running process is rclone. In my opinion this is a smoking gun that this is a software issue and not a hardware problem, which would typically panic the system in a random process, and sometimes even causing different panic types.
CPU: Intel(R) Xeon(R) Silver 4114 CPU @ 2.20GHz (2200.06-MHz K8-class CPU)
real memory = 137434759168 (131068 MB)
SuperMicro 5049P-E1CTR36L
Chelsio T520
Here are my panics:
cpuid = 8; apic id = 08
instruction pointer = 0x20:0xffffffff803f3674
stack pointer = 0x28:0xfffffe2015de8a60
frame pointer = 0x28:0xfffffe2015de8a90
current process = 52098 (rclone)
cpuid = 3; apic id = 03
stack pointer = 0x28:0xfffffe201589eac0
frame pointer = 0x28:0xfffffe201589eaf0
current process = 15932 (rclone)
cpuid = 11; apic id = 11
fault virtual address = 0x90
stack pointer = 0x28:0xfffffe2014667ac0
frame pointer = 0x28:0xfffffe2014667af0
current process = 86547 (rclone)
cpuid = 16; apic id = 16
stack pointer = 0x28:0xfffffe2015c7ba60
frame pointer = 0x28:0xfffffe2015c7ba90
current process = 29970 (rclone)
