D
Deleted member 95366
Guest
Hello community,
First my Hardware Config:
CELSIUS W370 [YKJR046276]
8GB RAM
Intel Core 2 Duo E8400 3GHz / 1333Mhz
MainboardMainboard type D2817
Formfactor BTX
Chipset Intel® Q45 Express, Intel® 82801JO ICH10DO
Chipset notes Intel® vPro™ technology dependent on processor type
Processor socket LGA 775
Processor quantity maximum 1
Memory slots 4 DIMM (DDR2)
Supported capacity RAM (max.) 16 GB
Memory frequency 800 MHz
Memory notes In configurations with 4 GB and more the visible memory may be reduced to approximately 3.5 GB or less (for 32-bit operating systems) and configurations with 8 GB the visible memory may be reduced to approximately 7.5 GB or less (depending on system configuration).
LAN Built-in 10/100/1000 MBit/s Intel® 82567LM
Audio codec Realtek ALC663
Audio features 5.1 surround sound, High Definition audio, Internal speaker supports audio playback
I was running freenas - FreeNAS-9.3-STABLE on a 8GB USB Stick for many years successfully on the system.
Then I was doing a dumb move:
I made an upgrade to FreeNAS 11.2 without making a backup of my configuration.
The update was successfuly and I was able to access the webinterface with 11.2
But then I shutdown the PC and now it does not boot anymore.
Do you have any ideas how to get it running again?
Is my Hardware compatible to FreeNAS 11.2?
8GB RAM
Formfactor BTX
