After an error message I have substituted physically the failing disk of a Pool, following the instruction for this version of FreeNas I have put offline the disk, substitute it and then tried to replace.
From the GUI I get this message:
From the command line I have first checked which are the DA for the new disk then which was the gptid and then run the command :
Of course the Pool name is correct
The gptid was retrieved from the zpool status:
But as you can see I am not able to replace it.
Tried to google and tested several solutions .... no way.
I have read several posts about ata disks but I have not found specific information for scsi disk.
Could you please help me?
Thanks
Select a valid choice. da47 is not one of the available choices
# zpool replace -f Pool-2 /dev/gptid/440095da-a217-11e8-bf5f-e41f13e5b4c8 /dev/da47 cannot replace /dev/gptid/440095da-a217-11e8-bf5f-e41f13e5b4c8 with /dev/da47: no such pool or dataset
gptid/c86354be-f0cc-11e5-885e-e41f13e5b4c8 ONLINE 0 0 0 gptid/ca154ea4-f0cc-11e5-885e-e41f13e5b4c8 ONLINE 0 0 0 11930542730379889181 OFFLINE 0 0 0 was /dev/gptid/440095da-a217-11e8-bf5f-e41f13e5b4c8
Thanks
