This was a new raidz2 build. I had a drive fail, it was replaced, but I made the mistake of setting it up as a spare instead of replacing the existing drive in the pool. Not the worst thing to happen but now I have an annoying warning light that the pool is degraded. Is there any possibility that I can convert the spare into an actual replacement without rebuilding everything? At this point the pool is in use.
Sorry for the stupid question, I knew better than this.
pool: tank state: DEGRADED status: One or more devices has been taken offline by the administrator. Sufficient replicas exist for the pool to continue functioning in a degraded state. action: Online the device using 'zpool online' or replace the device with 'zpool replace'. scan: resilvered 1.57M in 0 days 00:00:00 with 0 errors on Sat May 26 17:44:38 2018 config: NAME STATE READ WRITE CKSUM tank DEGRADED 0 0 0 raidz2-0 DEGRADED 0 0 0 gptid/ca363e73-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/cca8828b-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/d1b86990-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/d51049fe-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/d804819b-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/db20f312-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/dda24b58-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/e11d1f00-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 gptid/e39e8936-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 spare-9 DEGRADED 0 0 0 17637264324123775223 OFFLINE 0 0 0 was /dev/gptid/e55c7104-5d4d-11e8-aaf6-002590fde644 gptid/051c5d74-612e-11e8-8357-002590fde644 ONLINE 0 0 0 gptid/e837b4dd-5d4d-11e8-aaf6-002590fde644 ONLINE 0 0 0 logs gptid/4a426d0c-612b-11e8-8357-002590fde644 ONLINE 0 0 0 spares 227308045836062793 INUSE was /dev/gptid/051c5d74-612e-11e8-8357-002590fde644 errors: No known data errors
