Spencer Skinner
- Dec 22, 2016
Hi guys,
Having an issue with changing the amount of memory allocated to my Docker VM, I have gone to the FreeNAS VM UI and changed the allocated memory from 8192MB to 12288MB. I then restarted the VM to allow the change to take effect but when I looked at the RancherUI after the restart it still thought it had 8192MB on the host. I had the same issue in the past when I was trying to change the the disk image size from 20GB to 200GB, I ended up remaking the whole VM. I dont want to have to do that this time around though as my Docker is fully set up.
Any ideas? Is it a config within Docker I need to change?
Thanks
Spencer
Thanks
Spencer
