FreeNAS 11.0U4 on VMware - Okay to Delete Disk at VM Level?
JRE
My predecessor implemented FreeNAS 11.0U4 on VMware. He built several pools using several vDisks.
One of these pools can now be decommissioned and I want to reclaim the vDisk. I carefully did the following:
  • Used "zpool status" to determine the underlying storage for the pool
useengnas# zpool status APMR-CDD
pool: APMR-CDD​
state: ONLINE​
scan: scrub repaired 0 in 0h34m with 0 errors on Sun Mar 1 00:34:03 2020​
config:​
NAME STATE READ WRITE CKSUM
APMR-CDD ONLINE 0 0 0​
gptid/5624bd20-d604-11e7-9d06-005056b6569a ONLINE 0 0 0​
errors: No known data errors​
  • Used "gpart list" to match the pool to the storage device
useengnas# gpart list da2 | egrep -i "name|raw"​
Geom name: da2​
1. Name: da2p1​
rawuuid: 56133a64-d604-11e7-9d06-005056b6569a​
rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b​
2. Name: da2p2​
rawuuid: 5624bd20-d604-11e7-9d06-005056b6569a
rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b​
1. Name: da2​
  • Deleted SMB and NFS Shares from the zpool
  • Deleted the volume
Now I want to reclaim the virtual disk. In the User Guide, I see instructions for replacing a failed disk, but I do not see any instructions about how to simply remove a disk that is not in use. I see this: "If the hardware is not AHCI capable, shut down the system to physically replace the disk. When finished, return to the GUI and locate the OFFLINE disk." I presume AHCI is "Advanced Host Controller Interface" and I don't know what this means when I'm working on a VM.
My question is, can I use vSphere to remove the da2 disk while FreeNAS is running?
Many Thanks,
Janet
jenksdrummer
if da2 isn't used anywhere within the FreeNAS box (IE< not in a pool/boot/swap) and you want to dump the VMDK to reclaim space on your datastore, you should be able to remove it from the VMWare side of things w/o issue. FreeNAS and VMWare both support hot plug/unplug. May want to reboot it afterwards, or, play it safer and shut it down since a reboot wouldn't hurt.
