Fractal Node 804 and 2,5" drives
Octopuss
Looks like I infallibly grabbed the only brackets that only took the small screws, lol.
The 3 others I picked up today all use "regular" HDD screws, so I'm all good.
joeschmuck
Old Man
Of course, why should anything just be easy.
Which ones are you using? And can you post a link tot those as well? Not that I'm looking for any, but someone else might.
And maybe a photo of the finished product?
Octopuss
There is no finished product, I still can't get the SSDs (or HDDs for the record) to work with the new HBA as can be witnessed in the (now heavily derailed) other thread I have going on.
This is what I grabbed: https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/SSDs/SSD-Mounting-Bracket/p/CSSD-BRKT1
It's extremely light. I decided to keep this one instead of one of the double drive one where they are crammed on top of each other, because I have no idea how hot those PM883s SSDs can get, and it's better safe than sorry.
joeschmuck
Old Man
Thanks for the link. I like that it comes with screws for the SSD. I have not purchased a single SSD in a great many years that has come with screws. Very sad when 5 cents worth of screws can't be provided with the drive.
A few years ago I acquired something sort of similar from work. I was receiving a lot of Supermicro servers with removable drive trays that had a blank piece of galvanized steel to fill the carrier tray until it was replaced by a 3.5" hard drive. I took about 8 of these trays home, which were going to be scrap metal. I marked them up for holes for a SSD and drilled them out. They worked out great. The only downside is they were fairly thick metal and thus had a little weight to them, but they were free. I was able to mount two SSD on one tray, one SSD on each side using two screws diagonally to secure the drives in place.
I'm glad you found a product that works for you.
Octopuss
Can't you just look at the specs? I mean, uh... that's not so difficult I guess?
Etorix
