Folder shown under Sharing but is not under storage/Dataset
Lasse1981
Hi..
I have made a Pool and in that I have made 4 Datasets. I have attached a Screendump of it. But when I try to make another one called Tegnefilm, it says that there already is a dataset with that name.
Under Sharing SMB, I can also choose this folder to share it. But it's not present under datasets. What am I doing wrong here?
Seems like what you have there is a subdirectory... you would need to rename it or delete it to allow the creation of a dataset with the same name in the same location.
Lasse1981
@sretalla
It would make sence if there was a subfolder. But I cant see any. Look at the picture. I have attached a new one. Look at the size of the folders. It's like the "Tegnefilm" folder is hidden. It's counting the data, but it's not showing on the list.
From the GUI (Pools list), you can only see datasets, so if there's a directory there, you won't see it in that view.
I suggest going to the Shell tab and do a cd /mnt/NAS then ls -l.
If that doesn't show you the offending directory, then we have something else to worry about than what I was suggesting.
