Hi All,
Looking for some help, Have installed transmission and flexget in a standard jail with transmission.
When trying to run flexget, i'm getting the below error
Used this post https://forums.freenas.org/index.ph...tall-flexget-on-freenas-9-1-jail.14328/page-2 to install it. Wondering if this process has changed since FN11
Thanks
Steve
root@Transmission:~/.flexget # flexget database reset --sure 2018-01-11 07:43 VERBOSE manager Creating new database /root/.flexget/db-config.sqlite - DO NOT INTERUPT ... FATAL: Unable to use SQLite. Are you running Python 2.7, 3.3 or newer ? Python should normally have SQLite support built in. If you're running correct version of Python then it is not equipped with SQLite. You can try installing `pysqlite`. If you have compiled python yourself, recompile it with SQLite support. Error: No module named pysqlite2
Thanks
Steve
