Hi all, first time poster.
I recently installed a FreeNAS system at work ($20K monster supermicro based system) and I was really impressed by it. I decided to see if I could build something nice for home use using about 10% of that budget
Here's my hardware list (currently on the way from Newegg):
GIGABYTE GA-F2A85X-D3H FM2 AMD A85X (Hudson D4) SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard with UEFI BIOS - http://www.newegg.com/Product/Product.aspx?Item=N82E16813128577
AMD A8-5500 Trinity 3.2GHz (3.7GHz Turbo) Socket FM2 65W Quad-Core Desktop APU (CPU + GPU) with DirectX 11 Graphic AMD Radeon - http://www.newegg.com/Product/Product.aspx?Item=N82E16819113288
CORSAIR Vengeance 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model CMZ32GX3M4X1600C10 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820233232
8 x Seagate Barracuda 7200.14 ST3000DM001 3TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive - http://www.newegg.com/Product/Product.aspx?Item=N82E16822148844
4 x Intel EXPI9301CTBLK 10/ 100/ 1000Mbps PCI-Express Network Adapter - http://www.newegg.com/Product/Product.aspx?Item=N82E16833106033
NZXT Source 220 CA-SO220-01 Black Steel / Aluminum-like finish ATX Mid Tower Computer Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146083
Rosewill CAPSTONE Series CAPSTONE-650-M 650W ATX12V v2.31 & EPS12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified ... - http://www.newegg.com/Product/Product.aspx?Item=N82E16817182263
Kingston DataTraveler Micro 8GB USB 2.0 Flash Drive Model DTMCK/8GB - http://www.newegg.com/Product/Product.aspx?Item=N82E16820239113
D-Link DGS-1008G 10/100/1000Mbps Gigabit Desktop Switch - http://www.newegg.com/Product/Product.aspx?Item=N82E16833127325
My plan will be to setup 6 of the 8 disks in a RAIDZ2 for my main file server which is primarily accessed by CIFS/SMB (currently hosted on a raid 5 linux install... which will be rebuilt as a backup server). i'll also have access via sftp/ftp and possibly some other methods, but CIFS/SMB will be primary. I store videos (have a bunch of devices throughout the house that play video directly off the file store), photos and software primarily. I'm going to take the other two drives and mirror them for use as an iSCSI (file extent) datastore for my ESXi server. So I'll have 2 pools... 6 disks in a RAIDZ2 and a 2 disk mirror
I read the forums here pretty extensively prior to my purchase which is why I bought 4 Intel NICs (might be overkill, but hey; they are only 30 bucks
) and it's why I went with 32GB of RAM. My main switch is a Cisco 2970G, which I'm going to connect two of the NICs to in a LAG group for access to the main RAIDZ2 file store. The other two NICs will have jumbo frames enabled and will connect to the DGS-1008G for iSCSI (my ESXi server will also have two Intel Nics that connect to this switch, which is dedicated to iSCSI). The ESXi server will use round robin load balancing to talk to the datastore.
I'd love to hear any general comments on this build and what kind of performance I can expect.
I also have a question; one thing I haven't seen a ton of information on in the forums is compression and the tradeoffs involved. At work our FreeBSD expert told me I should always enabled compression on our systems at work (default compression) because it's basically free (performance wise). However, all the systems we deal with there are dual XEON or better server class boxes.
With the CPU I have selected should I expect any performance difference with compression on and off? (I do realize that might be a question that's hard to answer and I do intend to do some testing). (and I do realize the it's probably silly to enabled compression where I'm storing all my mkvs/jpgs)
Also, does anyone have experience running ESXi against a similar configuration over iSCSI? If so, what kind of performance do you get?
