wasdthemighty
- Mar 16, 2022
Hello everyone,
first time posting here :)
I have a simple question that I'd like to get an opinion on, I'd like to give you a panoramic first of my situation:
Here is my hardware:
CPU: i7-4790
RAM: 4x 4Gb modules of HYPERX 1866MHz
MOBO: ASUS Maximux Hero VII
STORAGE: PCIe Card with generic 256Gb M.2. SSD for the boot;
2x Samsung Sata SSDs 500Gb ( I think they are 870EVOs );
11x 2Tb Sata HDD 7.2K Rpm ( Various Brands );
COOLER: Artic Freezer eSports DUO
PSU: Thermaltake 500w modular
FANS: 3x 120mm fans + 1x 140mm fan from NZXT + 3x 120mm fans from Arctic
OS: Truenas Scale ( Truenas Core would not recognize my PCIe sata expansion card on boot giving the error "Root Mount waiting for CAM" )
Usage:
-Long term storage of Videos and Projects I worked on;
-Long term storage of media that I will watch using PLEX;
As you can see I don't need the NAS to be on 24/7, I would just turn it on when I need to save or get some file from it ( for 2/3 hours every weekend ) and when I want to consume some media using plex ( 2 hours every couple of days )
Qbservations:
I've then calculated the cost of running the NAS 24/7 ( https://imgur.com/a/yx4gdRx ) and it's absolutely out of my budget ( energy costs quite a bit here in Italy ).
I've used the website: https://outervision.com/power-supply-calculator with the following settings ( https://imgur.com/a/fHaeM0w )
Questions:
Does the website outervision.com calculate the power usage when the PC is IDLE or does it calculate it as if I was running the pc on "full beans" 24/7?
Given my utilization, should I turn on and then off the nas only when I need to? ( I think this would damage the drives but I'd like your opinion on it );
Is there something I can do to mitigate the power usage?
If someone has any suggestions please let me know :)
NOTES:
1. I just purchased a wattage monitor from Amazon which will arrive on friday so I can calculate precisely how much the nas is SUCCING from the wall when in IDLE;
2. I know I could have bought a sinology or similar nas that would use way less power but I really like building PCs aswell as experimenting and troubleshooting.
CPU: i7-4790
Usage:
Qbservations:
Questions:
NOTES:
