stefan.z.j
- Jan 24, 2018
Hey guys, first post first build here. Never had a NAS and figured it was about time to get one.
This NAS will mainly be used as a storage solution (~200 mb/s) but it should be able to handle some of the standard features and services like jails, FTP, rsync, cloud and low load web host. If it can handle HW-accelerated transcoding of 4k sources I would be very happy. HW-transcoding is not a requirement because I got a Skull Canyon, I would how ever like to re-purpose the NUC.
Feel free to give any and all suggestions. I am not dead set on this build and if you have any suggestions to make it better I would appreciate it but it is mainly compatibility issues that I am looking for.
I've roughly converted the prices into euros. They are not so much as to actually get the price but more so that you can make a rough comparison of the components that might require it.
MB:
Supermicro X11SSM-F: 228€
https://www.prisjakt.nu/produkt.php?p=3408017
---- OR. (Help, no clue how to reason) ----
Supermicro X11SSL-CF: 325€
* Do I need the SAS controller? Is it not better to get the newer chipset
https://www.prisjakt.nu/produkt.php?p=3408040
Memory:
2x Kingston DDR4 PC17000/2133MHz ECC CL15 8GB (D1G72M150): 2x128€ = 256€
*I really need help to figure out if this memory works, can't understand it from manufactures website: https://www.supermicro.com/products/motherboard/Xeon/C236_C232/X11SSM-F.cfm
* I changed memory from my old due the post by @Linkman
https://www.prisjakt.nu/produkt.php?p=3609338
CPU:
Intel Pentium G4620 3,7GHz Socket 1151: 102€
* Might be able to do HW-accelerated transcodes, if not, NUC can handle software.
https://www.prisjakt.nu/produkt.php?p=4094809
PSU:
Seasonic Platinum-520 Fanless 520W: 173€
* Ballpark calc: 6x30w (drives) + 50-80w (CPU) + ?50w? (other componets?) + 20% margin = 384w
* This is something I would like a bit of info on, I think this one is a little bit to expensive but maybe it is worth it?
https://www.prisjakt.nu/produkt.php?p=1478083
HD:
6x WD Red WD60EFRX 64MB 6TB: 199€
https://www.prisjakt.nu/produkt.php?p=2739254
Cache:
Random SSD, will figure this one out.
Thanks in advance
Stefan
PS:
I will include the amazon links if it helps FreeNAS when I get home, currently at work. The places I'm linking to is a Swedish price finder provider, I do not think it will hurt FreeNAS in any way.
Edit reasons:
1: Changed ram from incompatible ram.
MB:
Memory:
2x Hynix DDR4 PC19200/2400MHz ECC Reg CL17 8GB: 2x104€ = 208€
https://www.prisjakt.nu/produkt.php?p=4546470
---- OR A STUPID IDEA? ----
2x DDR3 PC3L-8500R 16GB ECC Reg: 2x80€ = 160€
* These have no more info on them from the store, but I assume they are generic? Will they work? They are not new but a lot of ram.
CPU:
PSU:
HD:
Cache:
Thanks in advance
Stefan
PS:
Edit reasons:
