PlaydohMask
- Jun 16, 2016
This will be my first freenas build and I'm hoping people can help me with the build :). The server will be for home use as a secondary file backup and a streaming server for the various devices. I don't think more than 2 persons will stream at a time so the build is probably an overkill. However, I'm also fairly lazy and I would rather not have to upgrade the machine again in a few years time.
Chasis: Fractal Design r5
Mobo: X11SSH-CTF (Probably a little overkill but the 10Gbps lan seems very useful for the next few years, especially since network is probably the bottleneck)
CPU: Xeon E3-1245 V5
CPU cooler: ???? (Haven't decided, any suggestions?)
Memory: 2x 16gb [Samsung M391A2K43BB1-CPB 16GB DDR4-2133 ECC Un-Buffer LP Server Memory]
Boot device: ???? (Thinking of getting a sata dom, however, they're fairly expensive. Is running 2 sata dom suggested?)
PSU: ???? (Haven't decided, I think most gold standard 650W or 750W PSU should suffice?)
UPS: ???? (Potentially moving to Asia soon where they use 220V which limits my UPS options).
HDD: 6x6tb in raidz2 [Mix of WD Red 6tb, Seagate nas 6tb and/or HGST Deskstar 6tb]
