Problem: The Firefly plug-in does not show under the plug-in section of the left side menu. While it does appear in the list of Installed plugins the service will not turn on.
Description:
I recently upgraded from 9.1 to 9.2.0 and then I installed Firefly from the FreeNAS GUI. While Firefly appears to have installed correctly its icon does not show under the plug-in section of the left side menu, which means I cannot reach its configuration dialog. Instead, /var/log/messages has:
Firefly is in the list of Installed plugins (it is the only one) but the service will not turn on either.
All of the instructions say to install the plug-in and its configuration UI will appear in the left menu. I deleted and reloaded Firefly but the results are the same.
HW/OS configuration
Build: FreeNAS-9.2.0-RELEASE-x64 (ab098f4) (Just upgraded from a fresh 9.1 install)
Platform: Intel(R) Celeron(R) CPU G540 @ 2.50GHz
Memory: 16256MB
Browser: Firefox 26
NW information
Plug-ins
Version: 1696_8
PBI: firefly-1696_8-amd64
Jails
IPv4 address: 192.168.2.14
Netmask: /24 (255.255.255.0)
Autostart: enabled
VIMAGE: enabled
Description:
Dec 31 12:50:27 freenas manage.py: [freeadmin.navtree:522] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/treemenu: timed out Dec 31 12:50:42 freenas dhclient: New IP Address (em0): 192.168.2.2 Dec 31 12:50:42 freenas dhclient: New Subnet Mask (em0): 255.255.255.0 Dec 31 12:50:42 freenas dhclient: New Broadcast Address (em0): 192.168.2.255 Dec 31 12:50:42 freenas dhclient: New Routers (em0): 192.168.2.1 Dec 31 12:51:49 freenas manage.py: [plugins.utils:87] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/status: HTTP Error 504: Gateway Time-out Dec 31 12:58:42 freenas manage.py: [plugins.utils:87] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/status: HTTP Error 504: Gateway Time-out Dec 31 13:14:33 freenas manage.py: [freeadmin.navtree:522] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/treemenu: timed out Dec 31 13:16:06 freenas manage.py: [plugins.utils:87] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/status: HTTP Error 504: Gateway Time-out Jan 1 12:43:03 freenas manage.py: [freeadmin.navtree:522] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/treemenu: timed out Jan 1 12:44:11 freenas manage.py: [plugins.utils:87] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/status: HTTP Error 504: Gateway Time-out Jan 1 13:58:29 freenas manage.py: [plugins.utils:87] Couldn't retrieve http://192.168.2.2/plugins/firefly/1/_s/status: HTTP Error 504: Gateway Time-out
HW/OS configuration
Memory: 16256MB
Browser: Firefox 26
NW information
root@freenas> ifconfig
em0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 150
0
options=42098<VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,WOL_MAGIC,VLAN_HWTSO>
ether 70:54:d2:1a:ec:9f
inet 192.168.2.2 netmask 0xffffff00 broadcast 192.168.2.255
nd6 options=29<PERFORMNUD,IFDISABLED,AUTO_LINKLOCAL>
media: Ethernet autoselect (1000baseT <full-duplex>)
status: active
ipfw0: flags=8801<UP,SIMPLEX,MULTICAST> metric 0 mtu 65536
options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
inet6 ::1 prefixlen 128
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x5
ether 02:aa:dd:89:8c:00
nd6 options=1<PERFORMNUD>
member: epair0a flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 7 priority 128 path cost 2000
member: em0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 1 priority 128 path cost 20000
epair0a: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu
1500
options=8<VLAN_MTU>
ether 02:b1:cb:00:07:0a
inet6 fe80::b1:cbff:fe00:70a%epair0a prefixlen 64 scopeid 0x7
status: active
Plug-ins
Version: 1696_8
Jails
Autostart: enabled
VIMAGE: enabled
[root@freenas ~]# jls
JID IP Address Hostname Path
2 - firefly_1 /mnt/Volume1/jails/firefly
_1
[root@freenas ~]# jexec 2 ifconfig -a
inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1
epair0b: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 1500
options=8<VLAN_MTU>
ether 02:43:53:00:08:0b
inet 192.168.1.14 netmask 0xffffff00 broadcast 192.168.1.255
inet6 fe80::43:53ff:fe00:80b%epair0b prefixlen 64 tentative scopeid 0x2
status: active
