Stranded Camel
 - May 25, 2017
I've upgraded to FreeNAS-11.0-RC3 (1d8ee7925) and have successfully created a Linux VM using bhyve through the web interface. It's all running swimmingly, and I'd like to back it up to an external disk now, but I've got one small problem -- I can't find its location.
In the device manager I see the following:
I've confirmed that the zvol at the bottom is what's selected as the place to store the VM's disk, and clearly some amount of disk space is being used (though the dataset and zvol numbers make no sense to me, as the dataset contains nothing but the zvol, and while the dataset does have compresion turned on (by mistake, really), I'm under the impression that a VM isn't going to compress much -- certainly not ).
When I SSH in to the FreeNAS box, however, it turns out that
So my questions are: (1) where are bhyve virtual machines located, and (2) is there any way to recognize them (e.g. a specific file extension)?
Thanks in advance!
 NAME							 USED			 AVAILABLE
SSD_Volume					   5.8 Gib (2%)	 214.2 GiB
  +---- SSD_Dataset			  10.2 GiB (4%)	203.0 GiB
			+---- Linux_VM_Zvol  10.2 GiB (4%)	207.4 GiBI've confirmed that the zvol at the bottom is what's selected as the place to store the VM's disk, and clearly some amount of disk space is being used (though the dataset and zvol numbers make no sense to me, as the dataset contains nothing but the zvol, and while the dataset does have compresion turned on (by mistake, really), I'm under the impression that a VM isn't going to compress much -- certainly not ).
 /mnt/SSD_Volume is completely empty.So my questions are: (1) where are bhyve virtual machines located, and (2) is there any way to recognize them (e.g. a specific file extension)?
Thanks in advance!
