So after being a long hold out on FreeNAS 11.3u5, I made the jump to TrueNAS 12.0u6.
I have to say, I am sort of impressed with how smooth it went, and how much better the new interface feels.
Main thing I notice is the GUI seems much faster. Specific actions like loading up the jails, and starting them are much faster.
Now the base system of my jail running Syncthing is still 11.3p14...
I want to upgrade this to a more current release of freebsd in order to update my Syncthing software to the latest version, receive security updates, etc.
My set up is pretty much identical to Toms from Lawerace Systems, and I am refrencing his upgrade video in order to upgrade the base system of my jail.
https://youtu.be/z0O6WHJz8I4
I get though all the steps up until 13 minutes 20 seconds of the above video.
After running the command:
the terminal output eventually is:
Then I page down all the way to the end of the list
After this I can no longer continue...
Like i said, in the video I am referencing Tom says he presses enter. But i was not able to do that.
Any help moving on would be appreciated.
I am also wondering if this is the only way to update the base system of the jail.
Is it possible to just stop my jail and change the default release under the basic properties, then continue to upgrade from there? ...all within the GUI…
| iocage upgrade -r 12.2-RELEASE |
| The following files will be added as part of updating to 12.2-RELEASE-p10: /boot/dtb/allwinner /boot/dtb/rockchip /boot/efi.4th /boot/gptboot.efi /boot/gptboot.efifat /etc/cron.d/at /etc/devd/devmatch.conf /etc/devd/iwmbtfw.conf /etc/newsyslog.conf.d/amd.conf /etc/newsyslog.conf.d/ftp.conf /etc/newsyslog.conf.d/lpr.conf /etc/newsyslog.conf.d/pf.conf /etc/newsyslog.conf.d/ppp.conf /etc/newsyslog.conf.d/sendmail.conf /etc/os-release /etc/rc.d/cfumass /etc/rc.d/devmatch /etc/rc.d/ippool /etc/rc.d/linux /etc/rc.d/os-release /etc/rc.d/sysvipc : |
| var/db/etcupdate/current/etc/cron.d /var/db/etcupdate/current/etc/cron.d/at /var/db/etcupdate/current/etc/devd/devmatch.conf /var/db/etcupdate/current/etc/devd/iwmbtfw.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/amd.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/ftp.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/lpr.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/pf.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/ppp.conf /var/db/etcupdate/current/etc/newsyslog.conf.d/sendmail.conf /var/db/etcupdate/current/etc/os-release /var/db/etcupdate/current/etc/rc.d/cfumass /var/db/etcupdate/current/etc/rc.d/devmatch /var/db/etcupdate/current/etc/rc.d/ippool /var/db/etcupdate/current/etc/rc.d/linux /var/db/etcupdate/current/etc/rc.d/os-release /var/db/etcupdate/current/etc/rc.d/sysvipc /var/db/etcupdate/current/etc/syslog.d /var/db/etcupdate/current/etc/syslog.d/ftp.conf /var/db/etcupdate/current/etc/syslog.d/lpr.conf /var/db/etcupdate/current/etc/syslog.d/ppp.conf /var/run/dhclient (END) |
