SOLVED Fibre channel domains
Brezlord
I have 2 single port Qlogic QLE2560 one sitting on each CPU in a Dell T620. I have a LUN setup and mounted on an ESXi 7 but only path is visible by the host, isp.0 domain 0. When I use a 2 port card both paths are visible. I'm wandering if this is because when using to separate cards the system creates a separate domain for each card.
TrueNAS-12.0-U5.1
root@nas1:~ # sysctl dev.isp.0
dev.isp.0.use_gff_id: 1
dev.isp.0.use_gft_id: 1
dev.isp.0.topo: 3
dev.isp.0.loopstate: 10
dev.isp.0.fwstate: 3
dev.isp.0.linkstate: 1
dev.isp.0.speed: 8
dev.isp.0.role: 1
dev.isp.0.gone_device_time: 30
dev.isp.0.loop_down_limit: 60
dev.isp.0.wwpn: 2377900762149597914
dev.isp.0.wwnn: 2305843168111669978
dev.isp.0.%domain: 0
dev.isp.0.%parent: pci1
dev.isp.0.%pnpinfo: vendor=0x1077 device=0x2532 subvendor=0x1077 subdevice=0x015c class=0x0c0400
dev.isp.0.%location: slot=0 function=0 dbsf=pci0:1:0:0 handle=\_SB_.PCI0.PEX1.NDX0
dev.isp.0.%driver: isp
dev.isp.0.%desc: Qlogic ISP 2532 PCI FC-AL Adapter
root@nas1:~ # sysctl dev.isp.1
dev.isp.1.use_gff_id: 1
dev.isp.1.use_gft_id: 1
dev.isp.1.topo: 3
dev.isp.1.loopstate: 10
dev.isp.1.fwstate: 3
dev.isp.1.linkstate: 1
dev.isp.1.speed: 8
dev.isp.1.role: 1
dev.isp.1.gone_device_time: 30
dev.isp.1.loop_down_limit: 60
dev.isp.1.wwpn: 2377900762149386453
dev.isp.1.wwnn: 2305843168111458517
dev.isp.1.%domain: 1
dev.isp.1.%parent: pci15
dev.isp.1.%pnpinfo: vendor=0x1077 device=0x2532 subvendor=0x1077 subdevice=0x015c class=0x0c0400
dev.isp.1.%location: slot=0 function=0 dbsf=pci0:66:0:0
dev.isp.1.%driver: isp
dev.isp.1.%desc: Qlogic ISP 2532 PCI FC-AL Adapter
Is there a hint that I can use to make both cards the same domain? Or am i barking up the wrong tree?
Brezlord
I'm using a Cisco DS-C9148-16p-K9 with 2 VSAN's so I have to SANs, SAN-A and SAN-B with one HBA in each.
SAN-MDS-1(config)# show zone
zone name SAN-A-R720-HOST-01-TrueNAS-01 vsan 100
  fcalias name R720-HOST-01-Slot4-Port1 vsan 100
    pwwn 21:00:00:24:ff:37:0a:80
  fcalias name TrueNAS-01-Slot1-Port1 vsan 100
    pwwn 21:00:00:24:ff:0e:b2:da
zone name SAN-A-R720-HOST-02-TrueNAS-01 vsan 100
  fcalias name R720-HOST-02-Slot4-Port1 vsan 100
zone name SAN-B-R720-HOST-01-TrueNAS-01 vsan 200
  fcalias name R720-HOST-01-Slot4-Port2 vsan 200
    pwwn 21:00:00:24:ff:37:0a:81
  fcalias name TrueNAS-01-Slot7-Port1 vsan 200
    pwwn 21:00:00:24:ff:0b:78:d5
zone name SAN-B-R720-HOST-02-TrueNAS-01 vsan 200
  fcalias name R720-HOST-02-Slot4-Port2 vsan 200
Brezlord
Going direct HBA to HBA works but through the switch it does not. Below is was get printed to the TrueNAS console when you plugin the fibre.
Oct  8 19:50:30 nas1.#####.com ctlfeasync: WWPN 0x2511547feedf7338 port 0xfffc08 path 10 target 0 arrived
Oct  8 19:51:01 nas1.#####.com ctlfeasync: WWPN 0x2511547feedf7338 port 0xfffc08 path 10 target 0 left
Oct  8 19:51:05 nas1.#####.com isp1: Chan 255 LINK FAILED
Oct  8 19:51:13 nas1.#####.com isp1: isp_handle_notify_24xx: Received INOT with status 2a on VP ff
Brezlord
All the hardware checks out good and I could not see and errors in the FC zoning so I just deleted all of the zones and recreated them and low and behold everything works now as it should.
Top Bottom
