Brezlord
- Jan 7, 2017
I have 2 single port Qlogic QLE2560 one sitting on each CPU in a Dell T620. I have a LUN setup and mounted on an ESXi 7 but only path is visible by the host, isp.0 domain 0. When I use a 2 port card both paths are visible. I'm wandering if this is because when using to separate cards the system creates a separate domain for each card.
TrueNAS-12.0-U5.1
Is there a hint that I can use to make both cards the same domain? Or am i barking up the wrong tree?
TrueNAS-12.0-U5.1
root@nas1:~ # sysctl dev.isp.0 dev.isp.0.use_gff_id: 1 dev.isp.0.use_gft_id: 1 dev.isp.0.topo: 3 dev.isp.0.loopstate: 10 dev.isp.0.fwstate: 3 dev.isp.0.linkstate: 1 dev.isp.0.speed: 8 dev.isp.0.role: 1 dev.isp.0.gone_device_time: 30 dev.isp.0.loop_down_limit: 60 dev.isp.0.wwpn: 2377900762149597914 dev.isp.0.wwnn: 2305843168111669978 dev.isp.0.%domain: 0 dev.isp.0.%parent: pci1 dev.isp.0.%pnpinfo: vendor=0x1077 device=0x2532 subvendor=0x1077 subdevice=0x015c class=0x0c0400 dev.isp.0.%location: slot=0 function=0 dbsf=pci0:1:0:0 handle=\_SB_.PCI0.PEX1.NDX0 dev.isp.0.%driver: isp dev.isp.0.%desc: Qlogic ISP 2532 PCI FC-AL Adapter root@nas1:~ # sysctl dev.isp.1 dev.isp.1.use_gff_id: 1 dev.isp.1.use_gft_id: 1 dev.isp.1.topo: 3 dev.isp.1.loopstate: 10 dev.isp.1.fwstate: 3 dev.isp.1.linkstate: 1 dev.isp.1.speed: 8 dev.isp.1.role: 1 dev.isp.1.gone_device_time: 30 dev.isp.1.loop_down_limit: 60 dev.isp.1.wwpn: 2377900762149386453 dev.isp.1.wwnn: 2305843168111458517 dev.isp.1.%domain: 1 dev.isp.1.%parent: pci15 dev.isp.1.%pnpinfo: vendor=0x1077 device=0x2532 subvendor=0x1077 subdevice=0x015c class=0x0c0400 dev.isp.1.%location: slot=0 function=0 dbsf=pci0:66:0:0 dev.isp.1.%driver: isp dev.isp.1.%desc: Qlogic ISP 2532 PCI FC-AL Adapter
