wraith
 - Dec 21, 2015
Hi All,
I'm currently planning to upgrade/update my server hardware. Whilst doing this upgrade, I might as well bring it up to current best practice (as I understand it) and seeking someone with fresh or more experienced perspective to provide some constructive feedback. At the moment, I'm planning to:
Queries on this chassis include:
- Move innards to a short-chassis rackmount server (I have a STRONG FS 42U enclosure which is an AV style so not deep. Need a short chassis);
 - Simplify the HDD's - move the files from vdev1 to vdev2 and remove the vedv1 drives. Vdev2, to date, has not accumulated more than 7Tb of data since built in early 2010's. And the 2 degrees of redundancy have served me well (I also backup to the cloud). This includes snapshots;
 - Add another 16Gb of RAM (same model as current) (link) as I would like to experiment with virtual machines, and;
 - Replace the boot USB with a small SSD
- SilverStone RM41-506
 - SilverStone RM400
 - Chenbro RM42300
 - TGC TGC-32380
 - SilverStone RM41-H08
 - SilverStone RM21-308
 - SilverStone CS350B
- Supports my microATX motherboard;
 - Will just fit my Corsair RM550x ATX PSU;
 - Will accept all 8 of my HDD's via external bays.
 - Comes with fans included
 - Has 2x2.5" internal slots for a boot SSD
- My current cooler is an Intel E97379-001 which is 70mm in height according to Uncle Google. The RM21-308 limitation for coolers is 68mm. Does the 2mm make a difference in practice (would like to use existing if possible)? Or should I get a new lower profile CPU cooler (such as the Noctua NH-L9I)? If I need a new cooler, what are respectable brands?
 - Are factory included fans generally of reasonable quality or should I allow for replacing them?
- Feedback on the above chassis' including quality, experience or any other options I haven't identified
 - Is there anything else I should consider whilst making this upgrade?
- No need to worry about order of HDD's when moving across. FreeNAS is clever enough to recognise each unique serial number and attach appropriately;
