Hi all,
not too sure where best to post this thread, so I though I'd try this one....
I'm trying to install Piwigo which requires an operational FAMP. I've largely followed the excellent guide by Samuel Dowling (https://www.samueldowling.com/2020/...n-freenas-iocage-jail-with-hardened-security/) on installing Nextcloud to get the FAMP base running.
It all looks rahter operational (I can access the server and load the PHP info webpage page to demonstrate that PHP is also operational).
So next step is, like for NextCloud, to run, via the webpage a script to configure Piwigo. on a browser, I type
Piwigo encountered a non recoverable error
PHP extension "mysqli" is not loaded
Mysqli is installed.
I can see 'mysqli' appears and is loaded, so not sure what is missing for Piwigo.....
Could anybody give me a hint as to where to look ?
Many thanks in advance !
(Config: FreeNAS 11.2. All above installed in a dedicated jail)
192.168.1.80/ => it finds it has to access 192.168.1.80/install.php, but displays a page saying :Piwigo encountered a non recoverable error
php -r 'phpinfo();' |grep mysqli gives the following output:Code:
/usr/local/etc/php/ext-20-mysqli.ini,
mysqli
mysqli.allow_local_infile => Off => Off
mysqli.allow_persistent => On => On
mysqli.default_host => no value => no value
mysqli.default_port => 3306 => 3306
mysqli.default_pw => no value => no value
mysqli.default_socket => no value => no value
mysqli.default_user => no value => no value
mysqli.max_links => Unlimited => Unlimited
mysqli.max_persistent => Unlimited => Unlimited
mysqli.reconnect => Off => Off
mysqli.rollback_on_cached_plink => Off => Off
API Extensions => mysqli,pdo_mysql
root@Piwigo:/ # php -v
PHP 7.2.34 (cli) (built: Oct 10 2020 01:11:56) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.2.34, Copyright (c) 1999-2018, by Zend Technologies
php -m gives the following output:Code:
[PHP Modules] apcu bcmath bz2 Core ctype curl date dom exif fileinfo filter gd gmp hash iconv imagick intl json ldap libxml mbstring mysqli mysqlnd openssl pcre PDO pdo_mysql posix redis Reflection session SimpleXML SPL standard xml xmlreader xmlwriter xsl Zend OPcache zip zlib [Zend Modules] Zend OPcache
