False Smart Alerts?
jamiejunk
I got some smart alerts of drives failing last week.
2016-03-24T00:02:25-07:00 san3 smartd[66081]: Device: /dev/da50, Self-Test Log error count decreased from 20 to 19
2016-03-24T05:02:09-07:00 san3 smartd[66081]: Device: /dev/da45, Self-Test Log error count increased from 2 to 3
Replaced the drives da45 and ds50. Then saw log entries saying stuff like this so that made me things were ok.
2016-03-24T13:02:10-07:00 san3 smartd[66081]: Device: /dev/da45, Self-Test Log error count decreased from 4 to 0
2016-03-24T13:02:13-07:00 san3 smartd[66081]: Device: /dev/da50, Self-Test Log error count decreased from 20 to 0
I don't see any more issues in the logs but I keep getting alert emails about smart errors on the two drives.
For example I just got this in an email 30 minutes ago:
Device: /dev/da50, Self-Test Log error count increased from 19 to 20
Device: /dev/da50, new Self-Test Log error at hour timestamp 36912
Any one have any ideas what's up? Am I getting false alerts on the drives? Do I need to clear something out?
m0nkey_
Please post the output of smartctl for both drives.
The fact that you replaced them and you're still seeing errors may suggest a bad cable, not a bad drive.
DrKK
FreeNAS Generalissimo
In fact,
Give us the full detail on this.
smartctl -x /dev/da45
for both drives, note the -x. Put the output in code braces.
jamiejunk
Here's the output:
da45
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p31 amd64] (local build)
Vendor:               SEAGATE
Product:              ST32000444SS
Revision:             0006
User Capacity:        2,000,398,934,016 bytes [2.00 TB]
Logical block size:   512 bytes
Rotation Rate:        7200 rpm
Form Factor:          3.5 inches
Logical Unit id:      0x5000c50034ec0d0f
Serial number:        9WM7GYDG00009206CJ1Y
Device type:          disk
Transport protocol:   SAS (SPL-3)
Local Time is:        Thu Mar 31 02:04:52 2016 PDT
SMART support is:     Available - device has SMART capability.
SMART support is:     Enabled
Temperature Warning:  Enabled
Read Cache is:        Enabled
Writeback Cache is:   Enabled
SMART Health Status: OK
Current Drive Temperature:     31 C
Drive Trip Temperature:        68 C
Manufactured in week 35 of year 2011
Specified cycle count over device lifetime:  10000
Accumulated start-stop cycles:  105
Specified load-unload count over device lifetime:  300000
Accumulated load-unload cycles:  105
Elements in grown defect list: 3
Vendor (Seagate) cache information
  Blocks sent to initiator = 874369640
  Blocks received from initiator = 1417526875
  Blocks read from cache and sent to initiator = 2607361264
  Number of read and write commands whose size <= segment size = 1839577655
  Number of read and write commands whose size > segment size = 6869
Vendor (Seagate/Hitachi) factory information
  number of hours powered up = 37041.07
  number of minutes until next internal SMART test = 55
Error counter log:
           Errors Corrected by           Total   Correction     Gigabytes    Total
               ECC          rereads/    errors   algorithm      processed    uncorrected
           fast | delayed   rewrites  corrected  invocations   [10^9 bytes]  errors
read:   2679864011       13         0  2679864024   2679864024      70816.421           0
write:         0        0         0         0          0      29550.513           0
verify:    54641        0         0     54641      54641          0.000           0
Non-medium error count:        3
SMART Self-test log
Num  Test              Status                 segment  LifeTime  LBA_first_err [SK ASC ASQ]
     Description                              number   (hours)
# 1  Background short  Completed                   -   37040                 - [-   -    -]
# 2  Background short  Completed                   -   36992                 - [-   -    -]
# 3  Background short  Completed                   -   36944                 - [-   -    -]
# 4  Background short  Completed                   -   36896                 - [-   -    -]
# 5  Background long   Completed                   -   36896                 - [-   -    -]
# 6  Background long   Completed                   -   36890                 - [-   -    -]
# 7  Background short  Completed                   -   36848                 - [-   -    -]
# 8  Background long   Completed                   -   36835                 - [-   -    -]
# 9  Background short  Completed                   -   36800                 - [-   -    -]
#10  Background short  Completed                   -   36776                 - [-   -    -]
#11  Background short  Completed                   -   36752                 - [-   -    -]
#12  Background short  Completed                   -   36728                 - [-   -    -]
#13  Background short  Completed                   -   36704                 - [-   -    -]
#14  Background short  Completed                   -   36680                 - [-   -    -]
#15  Background long   Completed                   -   36659                 - [-   -    -]
#16  Background short  Completed                   -   36633                 - [-   -    -]
#17  Background short  Completed                   -   36609                 - [-   -    -]
#18  Background short  Completed                   -   36585                 - [-   -    -]
#19  Background short  Completed                   -   36561                 - [-   -    -]
#20  Background short  Completed                   -   36537                 - [-   -    -]
Long (extended) Self Test duration: 18500 seconds [308.3 minutes]
Background scan results log
  Status: waiting until BMS interval timer expires
    Accumulated power on time, hours:minutes 37041:04 [2222464 minutes]
    Number of background scans performed: 423,  scan progress: 0.00%
    Number of background medium scans performed: 42937
   #  when        lba(hex)    [sk,asc,ascq]    reassign_status
   1  885:37  0000000022b688ec  [1,18,7]   Recovered via rewrite in-place
   2 1084:39  000000000424135a  [1,18,7]   Recovered via rewrite in-place
   3 1101:35  00000000042479af  [1,18,7]   Recovered via rewrite in-place
   4 1109:30  00000000042465b0  [1,18,7]   Recovered via rewrite in-place
   5 1134:53  000000000423ebd7  [1,18,7]   Recovered via rewrite in-place
   6 1171:49  0000000004240833  [1,18,7]   Recovered via rewrite in-place
   7 1177:35  0000000004244a44  [1,18,7]   Recovered via rewrite in-place
   8 1194:32  0000000000000c16  [1,18,7]   Recovered via rewrite in-place
   9 2683:43  0000000000000bd3  [1,18,7]   Recovered via rewrite in-place
  10 2877:06  0000000022c73bf3  [1,18,7]   Recovered via rewrite in-place
  11 2882:30  0000000022c57d4d  [1,18,7]   Recovered via rewrite in-place
  12 3096:47  0000000022c62306  [1,18,7]   Recovered via rewrite in-place
  13 3604:47  0000000000000ebc  [1,18,7]   Recovered via rewrite in-place
  14 3642:34  0000000000000ddd  [1,18,7]   Recovered via rewrite in-place
  15 4110:12  0000000000000bea  [1,18,7]   Recovered via rewrite in-place
  16 4111:29  0000000040218d11  [1,18,7]   Recovered via rewrite in-place
  17 4139:22  000000004e5b7b98  [1,18,7]   Recovered via rewrite in-place
  18 4140:46  00000000773ce28d  [1,18,7]   Recovered via rewrite in-place
  19 4241:27  0000000028b56ebf  [1,18,7]   Recovered via rewrite in-place
  20 5900:43  000000001c29a41b  [1,18,7]   Recovered via rewrite in-place
  21 6062:10  0000000000000bff  [1,18,7]   Recovered via rewrite in-place
  22 6583:43  00000000b9f5726c  [1,18,7]   Recovered via rewrite in-place
  23 6715:36  00000000314dbf74  [1,18,7]   Recovered via rewrite in-place
  24 6807:24  0000000000000c4c  [1,18,7]   Recovered via rewrite in-place
  25 7138:15  0000000000000dd3  [1,18,7]   Recovered via rewrite in-place
  26 7156:42  00000000256dbb1c  [1,18,7]   Recovered via rewrite in-place
  27 7578:14  0000000000000c77  [1,18,7]   Recovered via rewrite in-place
  28 7590:17  0000000000000bf1  [1,18,7]   Recovered via rewrite in-place
  29 8094:40  00000000e66867ed  [1,18,7]   Recovered via rewrite in-place
  30 8362:19  000000001c29ad5f  [1,18,7]   Recovered via rewrite in-place
  31 8541:40  00000000e5ba8896  [1,18,7]   Recovered via rewrite in-place
  32 8543:45  0000000079a52ede  [1,18,7]   Recovered via rewrite in-place
  33 8579:42  0000000000000c7e  [1,18,7]   Recovered via rewrite in-place
  34 8925:27  0000000000000dd2  [1,18,7]   Recovered via rewrite in-place
  35 9042:09  0000000000000c0d  [1,18,7]   Recovered via rewrite in-place
  36 10088:42  0000000000000bfb  [1,18,7]   Recovered via rewrite in-place
  37 10739:06  0000000000000bd1  [1,18,7]   Recovered via rewrite in-place
  38 10899:07  0000000000000e43  [1,18,7]   Recovered via rewrite in-place
  39 11130:04  000000002955c805  [1,18,7]   Recovered via rewrite in-place
  40 11243:16  00000000e442c930  [1,18,7]   Recovered via rewrite in-place
  41 11243:19  00000000e50c52ca  [1,18,7]   Recovered via rewrite in-place
  42 11243:22  00000000e5fbb719  [1,18,7]   Recovered via rewrite in-place
  43 11807:22  0000000000000bd2  [1,18,7]   Recovered via rewrite in-place
  44 11909:30  0000000035d21c7e  [1,18,7]   Recovered via rewrite in-place
  45 12030:16  0000000000000dd1  [1,18,7]   Recovered via rewrite in-place
  46 13032:15  0000000000000bd1  [1,18,7]   Recovered via rewrite in-place
  47 19102:43  0000000000400b53  [1,18,7]   Recovered via rewrite in-place
  48 19113:30  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
  49 19138:26  0000000000400ad5  [1,18,7]   Recovered via rewrite in-place
  50 19284:32  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  51 19413:33  0000000004a90bf4  [1,18,7]   Recovered via rewrite in-place
  52 19413:58  000000001b820901  [1,18,7]   Recovered via rewrite in-place
  53 19413:58  000000001c29a418  [1,18,7]   Recovered via rewrite in-place
  54 19575:27  0000000000489869  [1,18,7]   Recovered via rewrite in-place
  55 19604:45  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  56 19604:45  0000000000400cdf  [1,18,7]   Recovered via rewrite in-place
  57 19701:04  0000000000400bc2  [1,18,7]   Recovered via rewrite in-place
  58 19784:24  0000000000400cd3  [1,18,7]   Recovered via rewrite in-place
  59 19803:25  0000000001a4cf58  [1,18,7]   Recovered via rewrite in-place
  60 19803:55  000000001b40e8f8  [1,18,7]   Recovered via rewrite in-place
  61 20100:36  0000000000400b55  [1,18,7]   Recovered via rewrite in-place
  62 20124:59  0000000000400adb  [1,18,7]   Recovered via rewrite in-place
  63 20163:05  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  64 20170:31  0000000000400ad1  [1,18,7]   Recovered via rewrite in-place
  65 20176:12  0000000000400d86  [1,18,7]   Recovered via rewrite in-place
  66 20183:21  0000000000400b49  [1,18,7]   Recovered via rewrite in-place
  67 20277:28  00000000060bae0b  [1,18,7]   Recovered via rewrite in-place
  68 20780:43  000000001b2c9ec7  [1,18,7]   Recovered via rewrite in-place
  69 20790:24  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  70 20825:24  0000000000400d75  [1,18,7]   Recovered via rewrite in-place
  71 20826:58  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  72 20826:58  0000000000400da5  [1,18,7]   Recovered via rewrite in-place
  73 20844:26  0000000000400d05  [1,18,7]   Recovered via rewrite in-place
  74 20846:20  0000000000400d75  [1,18,7]   Recovered via rewrite in-place
  75 20849:34  0000000000400db5  [1,18,7]   Recovered via rewrite in-place
  76 20909:01  000000000c603f0f  [1,18,7]   Recovered via rewrite in-place
  77 20935:48  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  78 21002:46  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  79 21542:39  0000000000400d93  [1,18,7]   Recovered via rewrite in-place
  80 21621:43  00000000e8e046d6  [1,18,7]   Recovered via rewrite in-place
  81 21868:16  0000000000400ccf  [1,18,7]   Recovered via rewrite in-place
  82 21918:50  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
  83 21919:34  0000000000400d5e  [1,18,7]   Recovered via rewrite in-place
  84 21927:20  0000000000400cdd  [1,18,7]   Recovered via rewrite in-place
  85 21930:10  0000000000400b8d  [1,18,7]   Recovered via rewrite in-place
  86 21937:30  0000000000400dc8  [1,18,7]   Recovered via rewrite in-place
  87 22049:19  0000000000400db5  [1,18,7]   Recovered via rewrite in-place
  88 22327:54  0000000000400b90  [1,18,7]   Recovered via rewrite in-place
  89 22635:31  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  90 22829:33  00000000042fc328  [1,18,7]   Recovered via rewrite in-place
  91 22851:28  0000000000400d63  [1,18,7]   Recovered via rewrite in-place
  92 22995:26  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  93 23358:21  0000000000400cd5  [1,18,7]   Recovered via rewrite in-place
  94 23410:52  000000001b2c9676  [1,18,7]   Recovered via rewrite in-place
  95 23645:18  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  96 24002:15  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  97 24847:36  0000000000400d59  [1,18,7]   Recovered via rewrite in-place
  98 24851:06  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  99 24851:06  0000000000400bbe  [1,18,7]   Recovered via rewrite in-place
100 25302:11  0000000000400b53  [1,18,7]   Recovered via rewrite in-place
101 25511:58  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
102 25794:55  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
103 26011:52  0000000000400cd5  [1,18,7]   Recovered via rewrite in-place
104 26309:54  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
105 26636:06  0000000013f52515  [1,18,7]   Recovered via rewrite in-place
106 26789:53  0000000000400d68  [1,18,7]   Recovered via rewrite in-place
107 26803:43  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
108 26919:39  0000000000400b98  [1,18,7]   Recovered via rewrite in-place
109 27373:18  0000000000400b8d  [1,18,7]   Recovered via rewrite in-place
110 27374:36  0000000000400cce  [1,18,7]   Recovered via rewrite in-place
111 27509:41  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
112 27532:54  0000000010c1c352  [1,18,7]   Recovered via rewrite in-place
113 27796:38  0000000000400cd3  [1,18,7]   Recovered via rewrite in-place
114 27952:30  0000000000400b7c  [1,18,7]   Recovered via rewrite in-place
115 28307:26  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
116 28813:20  0000000000400acf  [1,18,7]   Recovered via rewrite in-place
117 29168:16  0000000000400ad6  [1,18,7]   Recovered via rewrite in-place
118 30033:06  0000000000400b4e  [1,18,7]   Recovered via rewrite in-place
119 30245:39  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
120 30250:45  0000000000400d7b  [1,18,7]   Recovered via rewrite in-place
121 30535:01  0000000000400b7f  [1,18,7]   Recovered via rewrite in-place
122 32579:43  00000000e8e04b36  [1,18,7]   Recovered via rewrite in-place
123 32973:54  0000000000400da4  [1,18,7]   Recovered via rewrite in-place
124 33391:36  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
33024 6917:44  0049011a01180900  [e,96,7]   Reassign status: reserved [0xc]
33025 11482:41  0060011e01180900  [d,fa,ff]   Reserved [0x3]
33026 13104:52  0002011e01180900  [0,0,2]   Reserved [0x0]
33027 22810:41  0050011901180900  [e,4b,38]   Reassignment by disk failed
33028 31167:32  0008011901180900  [8,e0,87]   Reassign status: reserved [0xe]
Protocol Specific port log page for SAS SSP
relative target port id = 1
  generation code = 0
  number of phys = 1
  phy identifier = 0
    attached device type: expander device
    attached reason: unknown
    reason: power on
    negotiated logical link rate: phy enabled; 3 Gbps
    attached initiator port: ssp=0 stp=0 smp=0
    attached target port: ssp=0 stp=0 smp=1
    SAS address = 0x5000c50034ec0d0d
    attached SAS address = 0x5003048000a3ab7f
    attached phy identifier = 18
    Invalid DWORD count = 0
    Running disparity error count = 0
    Loss of DWORD synchronization = 0
    Phy reset problem = 0
    Phy event descriptors:
     Invalid word count: 0
     Running disparity error count: 0
     Loss of dword synchronization count: 0
     Phy reset problem count: 0
relative target port id = 2
  generation code = 0
  number of phys = 1
  phy identifier = 1
    reason: unknown
    SAS address = 0x5000c50034ec0d0e
    attached SAS address = 0x5003048000a3abff
jamiejunk
da50
smartctl -x /dev/da50
Vendor:               SEAGATE
Revision:             0006
Logical Unit id:      0x5000c50034f38023
Serial number:        9WM7HGNG00009152KCTP
Device type:          disk
Local Time is:        Thu Mar 31 02:05:27 2016 PDT
Current Drive Temperature:     28 C
Elements in grown defect list: 0
  Blocks sent to initiator = 1056550268
  Blocks received from initiator = 2718171506
  Blocks read from cache and sent to initiator = 647985500
  Number of read and write commands whose size <= segment size = 580509091
  Number of read and write commands whose size > segment size = 2833
  number of hours powered up = 37023.02
  number of minutes until next internal SMART test = 3
Error counter log:
read:   1779221537       22         0  1779221559   1779221559      46720.442           0
write:         0        0         0         0          0      14692.554           0
verify:    52060        0         0     52060      52060          0.000           0
Non-medium error count:       16
SMART Self-test log
# 1  Background short  Completed                   -   37022                 - [-   -    -]
# 2  Background short  Completed                   -   36974                 - [-   -    -]
# 3  Background short  Completed                   -   36926                 - [-   -    -]
# 4  Background short  Completed                   -   36878                 - [-   -    -]
# 5  Background long   Completed                   -   36877                 - [-   -    -]
# 6  Background long   Completed                   -   36871                 - [-   -    -]
# 7  Background short  Completed                   -   36830                 - [-   -    -]
# 8  Background long   Completed                   -   36817                 - [-   -    -]
# 9  Background short  Completed                   -   36782                 - [-   -    -]
#10  Background short  Completed                   -   36758                 - [-   -    -]
#11  Background short  Completed                   -   36734                 - [-   -    -]
#12  Background short  Completed                   -   36710                 - [-   -    -]
#13  Background short  Completed                   -   36686                 - [-   -    -]
#14  Background short  Completed                   -   36662                 - [-   -    -]
#15  Background long   Completed                   -   36641                 - [-   -    -]
#16  Background short  Completed                   -   36615                 - [-   -    -]
#17  Background short  Completed                   -   36591                 - [-   -    -]
#18  Background short  Completed                   -   36567                 - [-   -    -]
#19  Background short  Completed                   -   36543                 - [-   -    -]
#20  Background short  Completed                   -   36519                 - [-   -    -]
    Accumulated power on time, hours:minutes 37023:01 [2221381 minutes]
    Number of background scans performed: 520,  scan progress: 0.00%
    Number of background medium scans performed: 17129
   1 9073:39  0000000000000b77  [1,18,7]   Recovered via rewrite in-place
   2 9088:03  0000000004250076  [1,18,7]   Recovered via rewrite in-place
   3 9117:36  000000000425d425  [1,18,7]   Recovered via rewrite in-place
   4 9200:45  0000000000000b5e  [1,18,7]   Recovered via rewrite in-place
   5 9217:13  000000000424fe42  [1,18,7]   Recovered via rewrite in-place
   6 9226:46  000000000425d66c  [1,18,7]   Recovered via rewrite in-place
   7 9283:08  0000000000000b64  [1,18,7]   Recovered via rewrite in-place
   8 9312:56  0000000023cbe069  [1,18,7]   Recovered via rewrite in-place
   9 9347:17  00000000042507ea  [1,18,7]   Recovered via rewrite in-place
  10 9431:54  0000000000000b51  [1,18,7]   Recovered via rewrite in-place
  11 9504:07  0000000000000d9e  [1,18,7]   Recovered via rewrite in-place
  12 9513:10  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  13 9584:16  0000000000000b67  [1,18,7]   Recovered via rewrite in-place
  14 9662:28  0000000000000b6a  [1,18,7]   Recovered via rewrite in-place
  15 9711:43  0000000000000b77  [1,18,7]   Recovered via rewrite in-place
  16 9825:14  0000000001ff5923  [1,18,7]   Recovered via rewrite in-place
  17 9874:20  0000000000000b4f  [1,18,7]   Recovered via rewrite in-place
  18 9943:39  0000000000000b57  [1,18,7]   Recovered via rewrite in-place
  19 10032:59  0000000000000b60  [1,18,7]   Recovered via rewrite in-place
  20 10095:48  0000000000000b4f  [1,18,7]   Recovered via rewrite in-place
  21 10215:15  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  22 10287:15  0000000000000b7c  [1,18,7]   Recovered via rewrite in-place
  23 10349:01  0000000000000d91  [1,18,7]   Recovered via rewrite in-place
  24 10376:29  0000000000000b6a  [1,18,7]   Recovered via rewrite in-place
  25 10497:19  0000000000000b78  [1,18,7]   Recovered via rewrite in-place
  26 10572:09  0000000000000b57  [1,18,7]   Recovered via rewrite in-place
  27 10734:43  0000000000000b64  [1,18,7]   Recovered via rewrite in-place
  28 10858:31  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  29 10929:03  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  30 11075:50  0000000000000d98  [1,18,7]   Recovered via rewrite in-place
  31 11080:13  0000000000000c41  [1,18,7]   Recovered via rewrite in-place
  32 11091:37  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  33 11168:05  0000000000000b66  [1,18,7]   Recovered via rewrite in-place
  34 11362:18  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  35 11452:56  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  36 11520:36  0000000000000db1  [1,18,7]   Recovered via rewrite in-place
  37 11599:41  0000000000000b6a  [1,18,7]   Recovered via rewrite in-place
  38 11656:30  000000003964c49d  [1,18,7]   Recovered via rewrite in-place
  39 11806:05  0000000000000b67  [1,18,7]   Recovered via rewrite in-place
  40 11948:08  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  41 12038:52  0000000000000d4e  [1,18,7]   Recovered via rewrite in-place
  42 12095:01  0000000000000bb8  [1,18,7]   Recovered via rewrite in-place
  43 12100:47  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  44 12251:53  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  45 12391:52  0000000000000b64  [1,18,7]   Recovered via rewrite in-place
  46 12502:31  0000000000000b68  [1,18,7]   Recovered via rewrite in-place
  47 12564:52  00000000e8e03f59  [1,18,7]   Recovered via rewrite in-place
  48 12663:49  0000000000000b53  [1,18,7]   Recovered via rewrite in-place
  49 12691:07  0000000000000e02  [1,18,7]   Recovered via rewrite in-place
  50 12728:32  0000000000000d4e  [1,18,7]   Recovered via rewrite in-place
  51 12751:33  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  52 12879:44  0000000000000b6a  [1,18,7]   Recovered via rewrite in-place
  53 12974:30  0000000000000b4e  [1,18,7]   Recovered via rewrite in-place
  54 13069:21  0000000000000b82  [1,18,7]   Recovered via rewrite in-place
  55 13254:59  0000000000000b5e  [1,18,7]   Recovered via rewrite in-place
  56 19099:02  00000000003ff92a  [1,18,7]   Recovered via rewrite in-place
  57 19104:12  00000000003ff898  [1,18,7]   Recovered via rewrite in-place
  58 19113:26  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
  59 19136:36  00000000003ff885  [1,18,7]   Recovered via rewrite in-place
  60 19147:32  00000000003ff864  [1,18,7]   Recovered via rewrite in-place
  61 19283:46  00000000003ff861  [1,18,7]   Recovered via rewrite in-place
  62 19378:45  00000000003ff87e  [1,18,7]   Recovered via rewrite in-place
  63 19565:40  00000000003ffb03  [1,18,7]   Recovered via rewrite in-place
  64 19568:40  00000000003ff879  [1,18,7]   Recovered via rewrite in-place
  65 19595:50  00000000003ffa32  [1,18,7]   Recovered via rewrite in-place
  66 19641:41  00000000003ff877  [1,18,7]   Recovered via rewrite in-place
  67 19693:12  00000000003ff88e  [1,18,7]   Recovered via rewrite in-place
  68 19700:47  00000000125aa70b  [1,18,7]   Recovered via rewrite in-place
  69 19706:17  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
  70 19924:36  00000000003ff870  [1,18,7]   Recovered via rewrite in-place
  71 19999:35  00000000003ff87e  [1,18,7]   Recovered via rewrite in-place
  72 20035:30  0000000002253928  [1,18,7]   Recovered via rewrite in-place
  73 20102:02  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
  74 20102:34  00000000003ffb30  [1,18,7]   Recovered via rewrite in-place
  75 20104:35  00000000003ffade  [1,18,7]   Recovered via rewrite in-place
  76 20126:29  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
  77 20134:25  00000000003ff86f  [1,18,7]   Recovered via rewrite in-place
  78 20151:27  00000000003ffa34  [1,18,7]   Recovered via rewrite in-place
  79 20157:06  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
  80 20158:59  00000000003ff86f  [1,18,7]   Recovered via rewrite in-place
  81 20165:04  00000000003ff839  [1,18,7]   Recovered via rewrite in-place
  82 20173:12  00000000003ff876  [1,18,7]   Recovered via rewrite in-place
  83 20179:00  00000000003ff833  [1,18,7]   Recovered via rewrite in-place
  84 20180:00  00000000003ffaeb  [1,18,7]   Recovered via rewrite in-place
  85 20181:52  00000000e8e082d9  [1,18,7]   Recovered via rewrite in-place
  86 20182:03  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
  87 20185:33  00000000003ff85e  [1,18,7]   Recovered via rewrite in-place
  88 20285:44  00000000003ff833  [1,18,7]   Recovered via rewrite in-place
  89 20502:30  00000000003ff87b  [1,18,7]   Recovered via rewrite in-place
  90 20788:25  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
  91 20827:32  00000000003ff86c  [1,18,7]   Recovered via rewrite in-place
  92 20930:24  00000000003ffa45  [1,18,7]   Recovered via rewrite in-place
  93 20931:27  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
  94 20941:31  00000000e8e080d9  [1,18,7]   Recovered via rewrite in-place
  95 20944:56  0000000000400ace  [1,18,7]   Recovered via rewrite in-place
  96 20949:00  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
  97 21542:25  00000000003ff86f  [1,18,7]   Recovered via rewrite in-place
  98 21550:43  00000000003ff881  [1,18,7]   Recovered via rewrite in-place
  99 21723:56  00000000003ff887  [1,18,7]   Recovered via rewrite in-place
 100 21863:16  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
 101 21922:09  00000000003ffa32  [1,18,7]   Recovered via rewrite in-place
 102 21932:50  00000000003ff85a  [1,18,7]   Recovered via rewrite in-place
 103 21936:57  00000000003ff897  [1,18,7]   Recovered via rewrite in-place
 104 21938:09  00000000096f7a8e  [1,18,7]   Recovered via rewrite in-place
 105 21946:13  00000000003ff833  [1,18,7]   Recovered via rewrite in-place
 106 22325:43  00000000003ff887  [1,18,7]   Recovered via rewrite in-place
 107 22333:07  00000000003ffb23  [1,18,7]   Recovered via rewrite in-place
 108 22344:09  00000000e8e04b8f  [1,18,7]   Recovered via rewrite in-place
 109 22636:40  00000000003ff863  [1,18,7]   Recovered via rewrite in-place
 110 22852:37  00000000003ff887  [1,18,7]   Recovered via rewrite in-place
 111 22922:37  00000000e8e082df  [1,18,7]   Recovered via rewrite in-place
 112 22965:23  00000000e53066f6  [1,18,7]   Recovered via rewrite in-place
 113 23271:31  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
 114 23640:28  00000000003ff864  [1,18,7]   Recovered via rewrite in-place
 115 23772:25  00000000003ffae6  [1,18,7]   Recovered via rewrite in-place
 116 23934:55  00000000003ff85e  [1,18,7]   Recovered via rewrite in-place
 117 24145:21  00000000003ff85e  [1,18,7]   Recovered via rewrite in-place
 118 24645:16  00000000003ff863  [1,18,7]   Recovered via rewrite in-place
 119 24790:51  00000000003ff8db  [1,18,7]   Recovered via rewrite in-place
 120 24846:55  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
 121 24935:13  00000000003ff86f  [1,18,7]   Recovered via rewrite in-place
 122 24997:10  00000000928be35d  [1,18,7]   Recovered via rewrite in-place
 123 25046:35  00000000003ff87c  [1,18,7]   Recovered via rewrite in-place
 124 25047:29  00000000003ffa92  [1,18,7]   Recovered via rewrite in-place
 125 25173:22  000000000bea5daf  [1,18,7]   Recovered via rewrite in-place
 126 25199:08  00000000003ff86f  [1,18,7]   Recovered via rewrite in-place
 127 25493:16  0000000000400cd0  [1,18,7]   Recovered via rewrite in-place
 128 25493:50  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
 129 25614:03  00000000003ffb31  [1,18,7]   Recovered via rewrite in-place
 130 25661:11  00000000003ffa9d  [1,18,7]   Recovered via rewrite in-place
 131 25687:03  00000000003ffa32  [1,18,7]   Recovered via rewrite in-place
 132 25836:00  00000000003ff863  [1,18,7]   Recovered via rewrite in-place
 133 26045:05  00000000003ff835  [1,18,7]   Recovered via rewrite in-place
 134 26285:02  00000000e8e07cc5  [1,18,7]   Recovered via rewrite in-place
 135 26285:09  00000000003ff839  [1,18,7]   Recovered via rewrite in-place
 136 26429:04  00000000003ff866  [1,18,7]   Recovered via rewrite in-place
 137 26513:54  0000000000400ad3  [1,18,7]   Recovered via rewrite in-place
 138 26573:00  0000000000400bc5  [1,18,7]   Recovered via rewrite in-place
 139 26655:52  00000000003ff863  [1,18,7]   Recovered via rewrite in-place
 140 26798:50  00000000003ffacb  [1,18,7]   Recovered via rewrite in-place
 141 26908:58  00000000003ff87b  [1,18,7]   Recovered via rewrite in-place
 142 27148:57  00000000003ff871  [1,18,7]   Recovered via rewrite in-place
 143 27292:50  00000000003ff836  [1,18,7]   Recovered via rewrite in-place
 144 27449:43  00000000e8e082d9  [1,18,7]   Recovered via rewrite in-place
 145 27460:53  00000000003ff835  [1,18,7]   Recovered via rewrite in-place
 146 27632:31  00000000003ff87b  [1,18,7]   Recovered via rewrite in-place
 147 27939:43  00000000003ffb14  [1,18,7]   Recovered via rewrite in-place
 148 27947:37  00000000003ff835  [1,18,7]   Recovered via rewrite in-place
 149 28155:46  00000000003ff832  [1,18,7]   Recovered via rewrite in-place
 150 28227:44  00000000003ff846  [1,18,7]   Recovered via rewrite in-place
 151 28395:38  00000000003ff864  [1,18,7]   Recovered via rewrite in-place
 152 28665:28  00000000003ff870  [1,18,7]   Recovered via rewrite in-place
 153 28730:27  00000000003ffa62  [1,18,7]   Recovered via rewrite in-place
 154 28880:26  00000000003ff864  [1,18,7]   Recovered via rewrite in-place
 155 29355:29  00000000003ff833  [1,18,7]   Recovered via rewrite in-place
 156 29670:17  00000000003ff87a  [1,18,7]   Recovered via rewrite in-place
 157 29674:17  00000000e8e082d9  [1,18,7]   Recovered via rewrite in-place
 158 29707:37  00000000d49deb4d  [1,18,7]   Recovered via rewrite in-place
 159 29946:01  00000000003ff882  [1,18,7]   Recovered via rewrite in-place
 160 30175:10  00000000003ff887  [1,18,7]   Recovered via rewrite in-place
 161 30244:25  00000000003ffad3  [1,18,7]   Recovered via rewrite in-place
 162 30245:19  00000000003ffa32  [1,18,7]   Recovered via rewrite in-place
 163 30250:15  00000000003ff833  [1,18,7]   Recovered via rewrite in-place
 164 30532:06  00000000003ff869  [1,18,7]   Recovered via rewrite in-place
 165 33378:36  00000000003ff835  [1,18,7]   Recovered via rewrite in-place
 33024 12607:29  0001011e0e1d0080  [e,92,ab]   Reserved [0x3]
 33025 12607:29  0001801e04808781  [e,92,ab]   Reserved [0x3]
 33026 21589:47  0008011c01180900  [0,40,4]   Reserved [0x0]
 33027 21623:55  0008011d01180900  [0,40,3]   Reserved [0x0]
 33028 22324:09  0010011a0e1d0080  [b,b7,79]   Reassignment by disk failed
 33029 22324:09  0010801a04808781  [b,b7,79]   Reassignment by disk failed
 33030 23251:08  0008011a01180900  [8,e0,85]   Reassign status: reserved [0xe]
 33031 24980:24  0008011a01180900  [8,e0,88]   Reassign status: reserved [0xe]
 33032 25932:10  0008011a01180900  [8,e0,87]   Reassign status: reserved [0xe]
 33033 26803:18  0008011c01180900  [8,e0,88]   Reassign status: reserved [0xe]
 33034 27792:46  0008011a01180900  [8,e0,88]   Reassign status: reserved [0xe]
 33035 28698:41  0008011b01180900  [8,e0,88]   Reassign status: reserved [0xe]
 33036 33169:50  0008011a0e1d0080  [8,e0,85]   Reassign status: reserved [0xe]
 33037 33169:50  0008801a04808781  [8,e0,85]   Reassign status: reserved [0xe]
 33038 33370:47  0068011c01180900  [1,ef,18]   Reassign status: reserved [0x9]
  generation code = 0
  number of phys = 1
  phy identifier = 0
    reason: power on
    SAS address = 0x5000c50034f38021
    attached phy identifier = 25
  generation code = 0
  number of phys = 1
  phy identifier = 1
    reason: unknown
    SAS address = 0x5000c50034f38022
DrKK
Maybe someone else can have an idea. These is a very unfamiliar set of SMART attributes for me, I assume because it's SAS.
Bidule0hm
Server Electronics Sorcerer
Yep, it's SAS drives. @cyberjock should know how to interpret them ;)
The big things to look at here are:
-> # of elements in the grown defect list
-> total uncorrected errors
-> Obviously SMART test results are important as well
