Device: /dev/ciss0 [cciss_disk_00] [SAT] error
titanve
Hello everyone!
I'm getting an email from my FreeNAS with this:
New alerts:
* Device: /dev/ciss0 [cciss_disk_00] [SAT], Self-Test Log error count increased from 2 to 3
Current alerts:
* Device: /dev/ciss0 [cciss_disk_00] [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct.
What does that mean?
Thank you in advance
HoneyBadger
actually does care
Administrator
Please post the full output of smartctl -a /dev/ciss0 so we can see the value for Reallocated_Sector_Ct and other SMART values - but generally speaking the rapid increase of this attribute is one of the primary indicators of a failed or failing drive.
It also means you might be using a RAID card instead of an HBA since the ciss driver is delivering your devices. Is this an HP P-series RAID card in passthrough/JBOD mode?
titanve
Hello HoneyBadger,
Thanks for your help!
This is the output:
[root@freenas ~]# smartctl -a /dev/ciss0
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.2-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
/dev/ciss0: Unable to detect device type
Please specify device type with the -d option.
Use smartctl -h to get a usage summary
[root@freenas ~]#
We have a HP SmartArray P410, but I don't know how to check the passthrough/JBOD mode, how do I check it?
Thanks!
titanve
We have a HP ML350 G6 Server
jgreco
Resident Grinch
Yeah, the CISS driver and/or the RAID card is a total train wreck. Do not use such a configuration if you want survivability.
HoneyBadger
actually does care
Administrator
The P410 has no passthrough functionality, therefore you're operating ZFS on top of RAID which is a major no-no for a stable and well-supported configuration.
Depending on your RAID configuration (single RAID0 drives vs. a RAID volume) you may need to poll your RAID card's controller to determine if there is an underlying hardware fault, but it seems like somehow a SMART alert has carried through to where FreeNAS can see it and alert you.
Ultimately the resolution to this will be backing up your pool, installing an HBA (not a RAID card) and recreating the pool.
titanve
What is HBA??
Can I just use my plain HDDs (we have 8 in the server) and let ZFS to do the RAID?
Thanks!
HoneyBadger
actually does care
Administrator
What is HBA??
Thanks!
HBA stands for Host Bus Adapter - it's a method of connecting more drives to your computer without adding any additional RAID logic in the middle.
Letting ZFS do the "RAID" work is exactly what should be done; however, if you presently have a RAID volume, there is no way to migrate the drives with their data intact into a ZFS-managed solution. You will need to:
1. Purchase a supported HBA, and ensure that it is flashed with a compatible LSI IT (Initiator/Target) mode firmware; some eBay sellers (such as theartofserver) will sell them pre-flashed and pre-tested. Suggested models are the Dell H200/H310, IBM M1015, or HP H220.
2. Back up all of your data from your existing ZFS-on-RAID pool to external source(s) and validate its integrity.
3. Export your current pool, optionally wiping the disks.
4. Shut down your system, install the HBA, and physically connect your hotswap bays to the HBA instead of the RAID card.
5. Boot back into FreeNAS and create a new pool on top of the independent drives.
6. Restore your data from the backup you created in step 2.
titanve
Can I do that just using NO RAID with my current SmartArray card?
I mean, deleting the present RAID config and just letting FreeNAS to "see" all the HDDs
Thanks
HoneyBadger
actually does care
Administrator
Thanks
No, unless something has changed since I last used one, the SmartArray P410 does not pass unconfigured drives through to the OS in a manner that can be used by FreeNAS.
titanve
Ok,
Thank you very much
jgreco
Resident Grinch
No, you can't. And that card is anything but "Smart." I have a small pile of them somewhere, and if I ever take up skeet shooting, they're on my shortlist of fodder.
The real problem here isn't whether or not you can pass unconfigured drives through to the OS. It's that the interactions between the driver, the RAID controller, and the disks are crap. You can absolutely get it to pass drives through, but you will still be subject to random controller issues if and when you run into disk problems. These festering PoS used to cause servers here to randomly pause and occasionally drop drives if there were problems with the underlying disk, because I used them in a non-RAID mode. The damn things are designed to assume you ARE running RAID and that they can just switch drives to pick up the data from redundancy. This is ZFS-unfriendly. Plus even that doesn't work quite right on FreeBSD.
titanve
Ok, thanks for your help jgreco
titanve
Hello!
Can I "do something" in order to clear those alerts?
Thanks!
HoneyBadger
actually does care
Administrator
Hello!
Thanks!
The alerts are a symptom - you need to correct the underlying problem.
Please try smartctl -d cciss,0 -a /dev/ciss0 to see if this will give actual results of the drive.
titanve
HDD1 has a red blinking light =(
Could it mean an error because of the P410 <-> ZFS or that the hard drive has problems?
Thanks
HoneyBadger
actually does care
Administrator
Could it mean a error because of the P410 <-> ZFS or that the hard drive has problems?
Thanks
That specific error is indicating that the drive has failed. You will need to replace it.
Before you do, please post output of zpool status - if you have made a single RAID0 for each disk you may not be able to transparently replace the drive in FreeNAS.
Even if this is resolved you should still migrate to a proper HBA solution.
titanve
Results:
[root@freenas ~]# smartctl -d cciss,0 -a /dev/ciss0
Device Model:     MB2000EAMZF
Serial Number:    9WM1MBQH
LU WWN Device Id: 5 000c50 02717392b
Firmware Version: HPG5
User Capacity:    2,000,398,934,016 bytes [2.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Wed Apr 10 09:54:57 2019 -05
SMART support is: Enabled
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: FAILED!
Drive failure expected in less than 24 hours. SAVE ALL DATA.
Warning: This result is based on an Attribute check.
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  609) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 338) minutes.
Conveyance self-test routine
recommended polling time:        (   3) minutes.
SCT capabilities:              (0x103d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   082   060   044    Pre-fail  Always       -       190662540
  3 Spin_Up_Time            0x0003   081   075   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       104
  5 Reallocated_Sector_Ct   0x0033   004   004   036    Pre-fail  Always   FAILING_NOW 3963
  7 Seek_Error_Rate         0x000f   064   060   030    Pre-fail  Always       -       2799695
  9 Power_On_Hours          0x0032   035   035   000    Old_age   Always       -       57724
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       102
180 Unknown_HDD_Attribute   0x003b   100   100   000    Pre-fail  Always       -       267140166
184 End-to-End_Error        0x0032   100   100   003    Old_age   Always       -       0
187 Reported_Uncorrect      0x0032   076   076   000    Old_age   Always       -       24
188 Command_Timeout         0x0032   100   099   000    Old_age   Always       -       21475164167
189 High_Fly_Writes         0x003a   091   091   000    Old_age   Always       -       9
190 Airflow_Temperature_Cel 0x0022   072   042   045    Old_age   Always   In_the_past 28 (0 159 28 22 0)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       3
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       97
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       1893
194 Temperature_Celsius     0x0022   028   058   000    Old_age   Always       -       28 (0 15 0 0 0)
195 Hardware_ECC_Recovered  0x001a   044   015   000    Old_age   Always       -       190662540
196 Reallocated_Event_Count 0x0033   004   004   036    Pre-fail  Always   FAILING_NOW 3963
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed: unknown failure    90%     57666         0
# 2  Short offline       Completed: unknown failure    90%     57498         0
# 3  Short offline       Completed: unknown failure    90%     57330         0
# 4  Short offline       Completed without error       00%     57162         -
# 5  Short offline       Completed without error       00%     56996         -
# 6  Short offline       Completed without error       00%     56828         -
# 7  Short offline       Completed without error       00%     56660         -
# 8  Short offline       Completed without error       00%     56492         -
# 9  Short offline       Completed without error       00%     56324         -
#10  Short offline       Completed without error       00%     56156         -
[root@freenas ~]#
[root@freenas ~]# zpool status
  pool: HDDLABB
 state: ONLINE
  scan: scrub repaired 0 in 0 days 01:01:12 with 0 errors on Sun Mar 10 01:01:15
 2019
        NAME                                          STATE     READ WRITE CKSUM
        HDDLABB                                       ONLINE       0     0     0
          gptid/31e18360-a6f1-11e8-91b6-0025b3adf25c  ONLINE       0     0     0
errors: No known data errors
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0 in 0 days 05:24:51 with 0 errors on Wed Apr  3 09:09:51
 2019
        freenas-boot  ONLINE       0     0     0
          mirror-0  ONLINE       0     0     0
            da1p2   ONLINE       0     0     0
            da2p2   ONLINE       0     0     0
[root@freenas ~]#
HoneyBadger
actually does care
Administrator
These lines should speak for themselves.
With close to 4000 reallocated sectors, this drive is well past its expiry date. Replace it now.
  pool: HDDLABB
state: ONLINE
2019
Your pool configuration indicates that you have build a RAID at the controller level. Replacing the drive should be possible without further interaction from the controller or ZFS, but you may need to reboot.
Again; this is an incredibly unsupported and ill-advised configuration.
titanve
Talking based on your experience, what is the "normal" life span of a hard drive? and what is good/best value hdd brand? WesternDigital? HGST? Seagate?
Thank you.
  pool: HDDLABB
state: ONLINE
2019
