Failed to sync git after hw change
turment
I saw many similar threads but none of them solved my problem.
After I moved the disks from Intel controller to a HBA one, I have the error:
Error: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/mnt/XeoPool/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/mnt/XeoPool/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: Cloning into '/mnt/XeoPool/ix-...
that many saw.
The motherboard time is correct and I can ping any destination or solve any domain name.
Any idea?
turment
This morning I reboot the system and the very same error appeared.
Is there any permanent fix? Should I open a issue?
Fleshmauler
Hardware details? HBA flashed to IT mode? Output of sas2flash -list to ensure you're on lastest firmware.
I actually had the same issue & for me it was unrelated to any HBA trickery; my router randomly decided it wanted a different IPv6 address for my NAS than what I had setup on my bridge. But if you're suspecting the HBA, then the first list of questions may be relevant.
turment
I don't think that's a HBA issue. I have the very same one in other TrueNAS and I have no errors at all.
Anyway:
LSI Corporation SAS2 Flash Utility
Version 20.00.00.00 (2014.09.18)
Copyright (c) 2008-2014 LSI Corporation. All rights reserved
        Adapter Selected is a LSI SAS: SAS2308_2(D1)
        Controller Number              : 0
        Controller                     : SAS2308_2(D1)
        PCI Address                    : 00:02:00:00
        SAS Address                    : 500605b-0-09c0-e5b0
        NVDATA Version (Default)       : 14.01.00.06
        NVDATA Version (Persistent)    : 14.01.00.06
        Firmware Product ID            : 0x2214 (IT)
        Firmware Version               : 20.00.07.00
        NVDATA Vendor                  : LSI
        NVDATA Product ID              : SAS9207-8i
        BIOS Version                   : 07.39.02.00
        UEFI BSD Version               : N/A
        FCODE Version                  : N/A
        Board Name                     : H220
        Board Assembly                 : H3-25278-05D
        Board Tracer Number            : SV44513205
        Finished Processing Commands Successfully.
        Exiting SAS2Flash.
turment
I have just found that there is a failed task for that error:
Fleshmauler
I'll be honest, neither did I - I only brought it up since you specified it happened after moving disks to HBA. Though now I realize that it could have been an issue & that reboot had made it apparent since I used to get this upon rebooting.
ChrisRJ
Sounds reasonable.
This is actually the reason why, if possible, I always recommend a reboot before any major change to a system. And it is always a good idea to change things one at a time and the check.
