FIX for App upgrades (missing ".../ix-applications/catalogs/" contents )
This may be a problem unique to me as my trueNAS Scale install process had a small hiccup, but I was trying to update plex and it gave this error
[ENOENT] Unable to locate 'plex' at '/mnt/(drive)/ix-applications/catalogs/github_com_truenas_charts_git_master/charts/plex'
This was after updating truenas scale to "Cobia" (23.10.1.3), which I only updated to because plex said I couldn't keep it on Angelfish and still update it.
I also got this error in there somewhere:
[EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/mnt/secksyboi/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: [EFAULT] Failed to clone 'https://github.com/truenas/charts.git' repository at '/mnt/(drive)/ix-applications/catalogs/github_com_truenas_charts_git_master' destination: Cloning into '/mnt/(drive)/ix-...
So anyway, turns out my '/mnt/(drive)/ix-applications/catalogs/' is empty and it's supposed to have a lot of stuff in it.
I'm not sure if it's supposed to work this way, but I manually copied this github into it:
Contents of this:
Goes Here
(you'll need to create the directory under that name)
I did it through SMB after lowering permissions on the directory but probably should have done it through the command line.
Anyways, plex upgraded after I transferred all that and I lived happily ever after. I hope this helps someone!
turment
I have a similar problem of yours but on stable Scale.
My content follows:
root@XeoNAS[/mnt/XeoPool/ix-applications]# root@XeoNAS[/mnt/XeoPool/ix-applications]# ls -long
total 28
-rw-r--r-- 1  76 Mar 28 12:58 app_migrations.json
drwxr-xr-x 5   5 Feb 28 20:16 backups
drwxr-xr-x 2   2 Mar 28 12:58 catalogs
-rw-r--r-- 1 338 May 30  2022 config.json
drwxr-xr-x 2   2 May 30  2022 default_volumes
drwxr-xr-x 5   5 May 30  2022 k3s
-rw-r--r-- 1 229 Mar 28 12:58 migrations.json
drwxr-xr-x 2   2 May 30  2022 releases
Do I need other contents?
I start thinking into an issue.
