I upgraded FreeNAS from v9.2 to v9.3.
When attempting to import the original volume I receive an error:
In the system log it shows that it 'failed to create mountpoint'.
I have scoured the forum for similar issues but I have been unsuccessful so far.
The zpool status shows the volume as online:
The hardware is as follows:
HP Proliant Microserver N36L
10GB Kingston ECC RAM
FreeNAS is installed on a 16GB Sandisk Fit USB
Vault volume is across 5x3TB drives
Should I be performing a zpool scrum of the volume and retry the import process?
What is actually happening when the system is trying to import the volume?
What system resources are need for this process to happen?
Should I be expanding the FreeNAS install disk space from 16GB?
Any help would be greatly appreciated.
Thank you.
Thank you.
