KoreanJesus
- Jun 17, 2014
Hi All,
After about a year of operation ive started to get warnings for a disc in my pool /dev/da1
dmesg Output:
http://pastebin.com/xC863qt8
Smart results for drive
Thanks for you time, If you need anymore info just let me know
-KJ
Dec 7 10:43:18 freenas smartd[3531]: Device: /dev/da1 [SAT], 14 Currently unreadable (pending) sectors Dec 7 10:43:18 freenas smartd[3531]: Device: /dev/da1 [SAT], Failed SMART usage Attribute: 5 Reallocated_Sector_Ct. Dec 7 11:13:18 freenas smartd[3531]: Device: /dev/da1 [SAT], FAILED SMART self-check. BACK UP DATA NOW!
dmesg Output:
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p25 amd64] (local build)
Model Family: Western Digital RE4-GP
Device Model: WDC WD2002FYPS-02W3B0
Serial Number: WD-WCAVY5380105
LU WWN Device Id: 5 0014ee 2afa2d392
Firmware Version: 04.01G01
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 5400 rpm
ATA Version is: ATA8-ACS (minor revision not indicated)
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Mon Dec 7 12:26:51 2015 GMT
SMART support is: Enabled
SMART overall-health self-assessment test result: FAILED!
See vendor-specific Attribute list for failed Attributes.
General SMART Values:
Offline data collection status: (0x85) Offline data collection activity
was aborted by an interrupting command from host.
Self-test execution status: ( 73) The previous self-test completed having
a test element that failed and the test
element that failed is not known.
data collection: (42900) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 488) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x303f) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 231 230 021 Pre-fail Always - 10408
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 21
5 Reallocated_Sector_Ct 0x0033 122 122 140 Pre-fail Always FAILING_NOW 619
7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0
9 Power_On_Hours 0x0032 086 086 000 Old_age Always - 10363
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 21
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 20
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 124 097 000 Old_age Always - 28
196 Reallocated_Event_Count 0x0032 001 001 000 Old_age Always - 496
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 14
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 22
SMART Error Log Version: 1
No Errors Logged
# 1 Conveyance offline Completed: unknown failure 90% 10354 -
# 2 Conveyance offline Completed without error 00% 10194 -
# 3 Conveyance offline Completed without error 00% 10030 -
# 4 Conveyance offline Completed without error 00% 9865 -
# 5 Conveyance offline Completed without error 00% 9697 -
# 6 Conveyance offline Completed without error 00% 9531 -
# 7 Extended offline Completed: read failure 80% 9496 893430786
# 8 Conveyance offline Completed without error 00% 9366 -
# 9 Conveyance offline Completed without error 00% 9198 -
#10 Conveyance offline Completed without error 00% 9033 -
#11 Conveyance offline Completed without error 00% 8866 -
#12 Conveyance offline Completed without error 00% 8703 -
#13 Conveyance offline Completed without error 00% 8536 -
#14 Conveyance offline Completed without error 00% 8369 -
#15 Conveyance offline Completed without error 00% 8202 -
#16 Conveyance offline Completed without error 00% 8034 -
#17 Conveyance offline Completed without error 00% 7867 -
#18 Conveyance offline Completed without error 00% 7699 -
#19 Conveyance offline Completed without error 00% 7532 -
#20 Conveyance offline Completed without error 00% 7365 -
#21 Conveyance offline Completed without error 00% 7197 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
/CODE
My System specs are as follows:
FreeNAS Build FreeNAS-9.3-STABLE-201509022158 x64
CPU: Intel Xeon CPU E3-1220 v3
RAM: Crucial CT2KIT102472BD160B 16GB 2x8GB
MOBO: Supermicro MBD-X10SL7-F-O
HDD:
6x WD RE4-GP WD2002FYPS 2TB
4x WD RED WDC WD20EFRX 2TB
I understand that the drive is failing but what I dont get is that the pool is reporting as good even though a scrub was run.
CODE
pool: all
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
scan: scrub repaired 3.39M in 16h41m with 0 errors on Sun Dec 6 16:41:40 2015
NAME STATE READ WRITE CKSUM
all ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/b0b73ff1-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b0f7f1ee-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b13bf6a4-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b18165bb-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b239ee6e-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b2bec352-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b32a9f00-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b38635c9-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b3e0eb7a-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
gptid/b43dad48-4720-11e4-90e3-001b217bf150 ONLINE 0 0 0
errors: No known data errors
-KJ
