EvanVanVan
 - Feb 1, 2014
Just a little background, yesterday I messed up my CIFS share, so I re-uploaded my config file and decrypted my drives.  Then I transfer several 10GB+ files over.  Usually I did one transfer at a time, but at the end I transferred 3 separate files at once (I mean each transfer had it's own progress window/bar).
I got another security email about exiting on signal 11 last night. Here's what the log says:I included the first line just to show that for 6 hours before the "exited on signal 11" everything was fine (That line at 14:43:41 has to do with when I restarted my server when re-uploading the config)
Anyway I know signal 11 usually has to deal with RAM, I had run 3-4 passes of MemTest at the beginning of August when I first got "exited on signal 11" security emails. My ram checked out fine.
This time thought I went to the Reporting screen and looked at memory. Here are the pics:
Right now (6:20 the next day), my memory utilization is still flat-lining at the same ~24GB.  The file transfers have been done since maybe 10pm last night.
I did have one error in the transfer, at the end of a 11GB file Windows popped up saying the network drive was inaccessible. The file hadn't finished transferring and I was forced to redo it...
Is that memory utilization normal? What about the exited on signal 11?
Thanks
edit: I just upgraded from 9.2.1.3 -> 9.2.1.7. I don't know if that's going to fix anything, but I'm going to transfer some files and watch memory utilization. Probably won't test it until tonight though.
Sep 1 14:43:41 freenas winbindd[9917]: initialize_winbindd_cache: clearing cache and re-creating with version number 2 Sep 1 20:03:20 freenas kernel: pid 9920 (smbd), uid 1001: exited on signal 11 Sep 1 20:45:37 freenas kernel: pid 12498 (smbd), uid 1001: exited on signal 11
	- Before 17:30 in the first picture my PMU was flat at 10Gb.
 - I don't know exactly when I was transfering files, but it had to be about when my memory utilization goes way up in the first pic.
 - I included the second and third pics just to show the weird dashes in the lines (unless that's just normal, slight utilization fluctuation.)
Thanks
