Using FreeNAS 8 and Windows 7 as client via CIFS / Samba I'm facing problems with processes being terminated by a signal 6 and signal 11 errors.
System:
The system has been up for a little over 15 days now. In the first days of it I moved a few TiB to my NAS without any troubles, even tested a few archives on the NAS to validate that they aren't corrupted as a result of the transfer.
Today I wanted to copy over some more data and that failed shortly after. The logs show that smbd is crashing:
As you can see, smbd dies because of a signal 6 and the periodicly executed python jobs fail with a signal 11. Even a simple csh dares to crash so there's clearly something wrong at the OS level. Top shows me the following information:
Correct me if I'm wrong here, but there's clearly more then enough memory available. What possible reasons can explain this behavior of crashing processes? I'd want to figure this out first before restarting FreeNAS as that'll surely fix things, but possibly only temporarily.
Edit: Diskspace can't explain things either:
System:
- Intel Xeon X3440 2.53Ghz Boxed | BX80605X3440
- 2 x Kingston 4GB 1333MHz DDR3 ECC Reg CL9 DIMM DR x8 w/TS VLP
- 7 x Western Digital Caviar GreenPower WD20EARS. 2TB | WD20EARS (RAIDZ2 6+1)
- Dual Intel® 82574L Gigabit Ethernet Controllers (onboard)
- OCZ Rally 2 8GB USB 2.0 Flash Drive
May 24 01:11:52 freenas freenas[1624]: Executing: /usr/bin/killall smbd May 24 01:11:52 freenas freenas[1624]: Executing: /usr/sbin/service samba quietstart May 24 10:11:52 freenas freenas: Removing stale Samba tdb files: ......... done May 24 01:11:59 freenas freenas[1624]: Executing: /usr/bin/killall nmbd May 24 10:11:59 freenas freenas: No matching processes were found May 24 01:11:59 freenas freenas[1624]: Executing: /usr/bin/killall smbd May 24 10:11:59 freenas freenas: No matching processes were found May 24 01:11:59 freenas freenas[1624]: Executing: /usr/sbin/service samba quietstart May 24 10:11:59 freenas freenas: Removing stale Samba tdb files: done May 24 10:11:59 freenas freenas: Starting nmbd. May 24 10:11:59 freenas freenas: Starting smbd. May 26 07:15:38 freenas sshd[18451]: login_getclass: unknown class 'root' May 26 07:15:57 freenas last message repeated 2 times May 26 10:14:12 freenas ntpd[3372]: kernel time sync status change 6001 May 26 10:26:56 freenas ntpd[3372]: kernel time sync status change 2001 May 27 08:11:28 freenas sshd[47889]: login_getclass: unknown class 'root' May 27 08:11:31 freenas sshd[47889]: login_getclass: unknown class 'root' May 31 18:26:17 freenas ntpd[3372]: kernel time sync status change 6001 May 31 18:43:23 freenas ntpd[3372]: kernel time sync status change 2001 Jun 1 06:18:47 freenas kernel: pid 98482 (smbd), uid 0: exited on signal 6 Jun 1 06:18:48 freenas kernel: pid 98490 (smbd), uid 0: exited on signal 6 Jun 1 06:18:48 freenas kernel: pid 98491 (smbd), uid 0: exited on signal 6 Jun 1 06:19:19 freenas kernel: pid 98495 (smbd), uid 0: exited on signal 6 Jun 1 06:19:20 freenas kernel: pid 98496 (smbd), uid 0: exited on signal 6 Jun 1 06:19:24 freenas kernel: pid 98497 (smbd), uid 0: exited on signal 6 Jun 1 06:19:24 freenas kernel: pid 98498 (smbd), uid 0: exited on signal 6 Jun 1 06:19:27 freenas kernel: pid 98499 (smbd), uid 0: exited on signal 6 Jun 1 06:19:27 freenas kernel: pid 98500 (smbd), uid 0: exited on signal 6 Jun 1 06:19:28 freenas kernel: pid 98501 (smbd), uid 0: exited on signal 6 Jun 1 06:19:28 freenas kernel: pid 98502 (smbd), uid 0: exited on signal 6 Jun 1 06:19:28 freenas kernel: pid 98503 (smbd), uid 0: exited on signal 6 Jun 1 06:19:29 freenas kernel: pid 98504 (smbd), uid 0: exited on signal 6 Jun 1 06:19:29 freenas kernel: pid 98505 (smbd), uid 0: exited on signal 6 Jun 1 06:19:29 freenas kernel: pid 98506 (smbd), uid 0: exited on signal 6 Jun 1 06:19:30 freenas kernel: pid 98507 (smbd), uid 0: exited on signal 6 Jun 1 06:19:30 freenas kernel: pid 98508 (smbd), uid 0: exited on signal 6 Jun 1 06:19:46 freenas kernel: pid 98509 (smbd), uid 0: exited on signal 6 Jun 1 06:20:01 freenas kernel: pid 98514 (python), uid 0: exited on signal 11 Jun 1 06:22:55 freenas freenas[1624]: Executing: /usr/bin/killall nmbd Jun 1 06:22:55 freenas freenas[1624]: Executing: /usr/bin/killall smbd Jun 1 06:22:55 freenas freenas[1624]: Executing: /usr/sbin/service samba quietstart Jun 1 15:22:55 freenas freenas: Removing stale Samba tdb files: ........ done Jun 1 06:23:02 freenas freenas[1624]: Executing: /usr/bin/killall nmbd Jun 1 15:23:02 freenas freenas: No matching processes were found Jun 1 06:23:02 freenas freenas[1624]: Executing: /usr/bin/killall smbd Jun 1 15:23:02 freenas freenas: No matching processes were found Jun 1 06:23:02 freenas freenas[1624]: Executing: /usr/sbin/service samba quietstart Jun 1 15:23:02 freenas freenas: Removing stale Samba tdb files: done Jun 1 15:23:02 freenas freenas: Starting nmbd. Jun 1 15:23:02 freenas freenas: Starting smbd. Jun 1 06:23:09 freenas kernel: pid 98720 (smbd), uid 0: exited on signal 6 Jun 1 06:23:09 freenas kernel: pid 98721 (smbd), uid 0: exited on signal 6 Jun 1 06:23:09 freenas kernel: pid 98722 (smbd), uid 0: exited on signal 6 Jun 1 06:23:10 freenas kernel: pid 98723 (smbd), uid 0: exited on signal 6 Jun 1 06:23:10 freenas kernel: pid 98724 (smbd), uid 0: exited on signal 6 Jun 1 06:23:11 freenas kernel: pid 98726 (smbd), uid 0: exited on signal 6 Jun 1 06:23:11 freenas kernel: pid 98727 (smbd), uid 0: exited on signal 6 Jun 1 06:23:11 freenas kernel: pid 98728 (smbd), uid 0: exited on signal 6 Jun 1 06:23:12 freenas kernel: pid 98729 (smbd), uid 0: exited on signal 6 Jun 1 06:23:12 freenas kernel: pid 98730 (smbd), uid 0: exited on signal 6 Jun 1 06:23:12 freenas kernel: pid 98732 (smbd), uid 0: exited on signal 6 Jun 1 06:23:12 freenas kernel: pid 98733 (smbd), uid 0: exited on signal 6 Jun 1 06:25:00 freenas kernel: pid 98812 (python), uid 0: exited on signal 11 Jun 1 06:25:08 freenas kernel: pid 43454 (csh), uid 0: exited on signal 11 (core dumped) Jun 1 15:25:39 freenas login: ROOT LOGIN (root) ON ttyv4 Jun 1 06:26:17 freenas kernel: pid 98850 (csh), uid 0: exited on signal 11 (core dumped) Jun 1 15:26:22 freenas login: ROOT LOGIN (root) ON ttyv4 Jun 1 06:30:00 freenas kernel: pid 99096 (python), uid 0: exited on signal 11 Jun 1 06:35:00 freenas kernel: pid 99368 (python), uid 0: exited on signal 11 Jun 1 06:40:00 freenas kernel: pid 99627 (python), uid 0: exited on signal 11 Jun 1 15:42:39 freenas sshd[99764]: login_getclass: unknown class 'root' Jun 1 15:42:43 freenas sshd[99764]: login_getclass: unknown class 'root' Jun 1 06:45:01 freenas kernel: pid 99971 (python), uid 0: exited on signal 11 Jun 1 06:50:00 freenas kernel: pid 634 (python), uid 0: exited on signal 11
last pid: 1231; load averages: 0.03, 0.01, 0.00 up 15+03:39:59 15:55:26 47 processes: 1 running, 46 sleeping CPU: 0.1% user, 0.0% nice, 0.1% system, 0.0% interrupt, 99.8% idle Mem: 58M Active, 21M Inact, 4431M Wired, 22M Cache, 142M Buf, 1621M Free Swap: 4096M Total, 54M Used, 4042M Free, 1% Inuse PID USERNAME THR PRI NICE SIZE RES STATE C TIME WCPU COMMAND 1711 root 7 44 0 70160K 3828K ucond 0 6:53 0.00% collectd 7570 root 1 44 0 9224K 1484K select 6 2:45 0.00% top 86474 root 1 44 0 15560K 868K nanslp 0 2:35 0.00% zpool 1624 root 6 44 0 139M 55492K uwait 2 1:09 0.00% python 2055 www 1 44 0 19328K 2032K kqread 2 0:54 0.00% lighttpd 3372 root 1 44 0 11780K 892K select 2 0:24 0.00% ntpd 1821 root 1 47 0 7832K 388K nanslp 4 0:04 0.00% cron ...
freenas# df Filesystem 1K-blocks Used Avail Capacity Mounted on /dev/ufs/FreeNASs1a 468735 409051 22185 95% / devfs 1 1 0 100% /dev /dev/md0 4526 2316 1848 56% /etc /dev/md1 686 10 622 2% /mnt /dev/md2 76526 28194 42210 40% /var /dev/ufs/FreeNASs4 20263 892 17750 5% /data mpool 953679750 21 953679729 0% /mnt/mpool rpool 4308178077 56 4308178021 0% /mnt/rpool ...
