lexxai
- Nov 9, 2016
I create VM machine with freebsd on FreeNAS and want run inside vm PPPOE server.
But tap interface can't see any packets of ether type 0x8863.
Where it can be ?
ifconfig
At HOST:
Inside of VM:
tcpdump
result OK
result OK
result noting
Where it can be ?
ifconfig
At HOST:
ifconfig bridge2
bridge2: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> metric 0 mtu 9000
ether 02:a2:bf:XX:XX:XX
nd6 options=1<PERFORMNUD>
groups: bridge
member: tap1 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 16 priority 128 path cost 2000000
member: lagg0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
ifmaxaddr 0 port 6 priority 128 path cost 10000
Inside of VM:
vtnet1: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 9000
options=80028<VLAN_MTU,JUMBO_MTU,LINKSTATE>
ether 00:a0:98:XX:XX:XX
hwaddr 00:a0:98:XX:XX:XX
inet6 fe80::2a0:98XX:XXXX:1664%vtnet1 prefixlen 64 scopeid 0x2
inet 172.16.XX.XX netmask 0xffffff00 broadcast 172.16.XX.255
media: Ethernet 10Gbase-T <full-duplex>
status: activetcpdump
>tcpdump -i bridge2 -e ether proto 0x8863 04:09:28.994923 d8:50:e6:41:XX:XX (oui Unknown) > Broadcast, ethertype PPPoE D (0x8863), length 96: PPPoE PADI [Service-Name] [Host-Uniq 0x210000000000000036000000]
result OK
tcpdump -i lagg0 -e ether proto 0x8863 04:13:25.107190 d8:50:e6:41:XX:XX (oui Unknown) > Broadcast, ethertype PPPoE D (0x8863), length 96: PPPoE PADI [Service-Name] [Host-Uniq 0x23000000000000003A000000]
result OK
> tcpdump -i tap1 -e ether proto 0x8863
result noting
