My lego:
dell t110, xeon 2.4, 16gb ram, 3 local 250gb sata volumes in a local host raid 1 with hot spare (dont think they are sas) running vmware 5.5
in the x8 slot, hba qlogic qle2464 -> NetApp ds14 mk2 AT (dual controllers) directly, no filer (head) and no mpio configured (yet). loaded with 14x 1tb drives. Single loop connected
Vmware wont passthrough my HBA, so RDM (expletives), aparently only the 8gb 25xx serious and some higher 16gb cards are compatible with pass through. makes very little sense, so I tried to arbitrarily config the passthrough file with a def to allow my 4gb cards through, shot in the dark and it failed.
If you have a suggestion on a better coarse of action, please provide your feedback, I'm definitely open to a better solution with the following restrictions.
I'm done on my budget for lego for a while, so purchasing another box to go bare metal controller on my fc 'san' draw isnt an option, since there is no money for another box, there surely isnt any money for a filer head from netapp.
My configuration is such that nas handles a zfs raid 6 style volume presenting a few iscsi data sets.
My plan is to have the nas boot off of the local disks on the vmware host, come up, bring up the clustered storage and zfs which would hten bring up the other vm's and storage.
The current problem other than it takes an eon to boot the san and vmware and have them play nicely together is that when writing to the san, I get wonderful burst of quite brilliant speeds, the speeds I expect, however I something resets and the whole process pauses stops mid transfer, then bursts again for a short period of sustained transfer before dieing again.
The errors reported are not unheard of, but I'm not sure how to resolve them:
WRITE(6) / READ(10)
CAM status: SCSI Status Error
SCSI status: Busy
Retrying command
which would seem to be bsd recieving commands from the hd's and not handling them properly though that could be a red herring, those are normal commands from a controller? Why would that cause a drop/pause in transmittion.
In any case, I can live with the poor startup if I can get my storage working sufficently efficiently. Ideas?
WRITE(6) / READ(10)
SCSI status: Busy
Retrying command
