errors: 1 data errors, use '-v' for a list
Ramboxman
I keep getting this zpool status -v see below can I delete this file? Is this a bug anyone else seen this error?
//usr/local/lib/migrate93/freenasUI/services/migrations/__pycache__/0165_fix_ddns_domains_delimiters.cpython-36.pyc
Ramboxman
I believe I deleted the file in question that was causing the 1 data error, use 'V' for a list, although not sure of the consequences yet.
root@freenas:/usr/local/lib/migrate93/freenasUI/services/migrations/__pycache__ # ls
__init__.cpython-36.pyc
0001_initial.cpython-36.pyc
0002_auto__add_field_cifs_cifs_srv_homedir_enable__add_field_cifs_cifs_srv_.cpython-36.pyc
0003_auto__add_field_activedirectory_ad_workgroup__add_field_ldap_ldap_ssl_.cpython-36.pyc
0004_auto__add_field_ssh_ssh_host_dsa_key__add_field_ssh_ssh_host_dsa_key_p.cpython-36.pyc
0005_auto__add_iscsitargetauthorizedinitiator__add_iscsitargetextent__add_i.cpython-36.pyc
0006_auto__del_unison__del_rsyncjob__del_bittorrent__del_webserver__add_fie.cpython-36.pyc
0007_auto__add_field_cifs_cifs_srv_authmodel.cpython-36.pyc
0008_auto__del_field_cifs_cifs_srv_recvbuffer__del_field_cifs_cifs_srv_send.cpython-36.pyc
0009_auto__add_field_ftp_ftp_anonpath.cpython-36.pyc
0010_auto__add_field_activedirectory_ad_windows_version__add_field_activedi.cpython-36.pyc
0011_auto__add_field_ftp_ftp_anonpath.cpython-36.pyc
0012_auto__chg_field_ftp_ftp_anonuserbw__chg_field_ftp_ftp_timeout__chg_fie.cpython-36.pyc
0013_auto__add_field_ftp_ftp_port.cpython-36.pyc
0014_auto__del_field_iscsitargetglobalconfiguration_iscsi_mediadirectory__c.cpython-36.pyc
0015_auto__chg_field_iscsitargetglobalconfiguration_iscsi_luc_authnetwork__.cpython-36.pyc
0016_auto__del_field_iscsitargettoextent_iscsi_target_lun.cpython-36.pyc
0017_auto__chg_field_iscsitarget_iscsi_target_portalgroup__chg_field_iscsit.cpython-36.pyc
0018_auto__chg_field_iscsitargetauthcredential_iscsi_target_auth_tag__chg_f.cpython-36.pyc
0019_auto__chg_field_iscsitargetextent_iscsi_target_extent_filesize.cpython-36.pyc
0020_auto__add_field_afp_afp_srv_guest_user.cpython-36.pyc
0021_auto__add_field_nfs_nfs_srv_async.cpython-36.pyc
0022_auto__add_field_cifs_cifs_srv_homedir_browseable_enable.cpython-36.pyc
0023_auto__add_field_cifs_cifs_srv_homedir.cpython-36.pyc
0024_auto__del_field_dynamicdns_ddns_wildcard.cpython-36.pyc
0025_auto__del_field_activedirectory_ad_windows_version__del_field_activedi.cpython-36.pyc
0026_add_model_Rsyncd.cpython-36.pyc
0027_add_model_RsyncMod.cpython-36.pyc
0028_auto__chg_field_tftp_tftp_username__chg_field_afp_afp_srv_guest_user__.cpython-36.pyc
0029_iscsi_name_changing.cpython-36.pyc
0030_auto__chg_field_ftp_ftp_anonpath__chg_field_rsyncmod_rsyncmod_path__ch.cpython-36.pyc
0031_auto__chg_field_iscsitargetportal_iscsi_target_portal_listen__chg_fiel.cpython-36.pyc
0032_auto__add_field_iscsitarget_iscsi_target_serial.cpython-36.pyc
0033_auto__add_smart.cpython-36.pyc
0034_auto__add_unique_iscsitargetextent_iscsi_target_extent_name.cpython-36.pyc
0035_device_extents_changing.cpython-36.pyc
0036_identify_dextents_serial_or_devname.cpython-36.pyc
0037_auto__chg_field_nfs_nfs_srv_servers.cpython-36.pyc
0038_auto__chg_field_ssh_ssh_tcpport.cpython-36.pyc
0039_auto__chg_field_tftp_tftp_port.cpython-36.pyc
0040_auto__add_field_ups_ups_masterpwd__add_field_ups_ups_extrausers.cpython-36.pyc
0041_auto__del_field_afp_afp_srv_ddp.cpython-36.pyc
0042_ldap_ssl.cpython-36.pyc
0043_auto__add_field_afp_afp_srv_connections_limit.cpython-36.pyc
0043_iscsi_extents.cpython-36.pyc
0044_auto__add_field_activedirectory_ad_allow_trusted_doms.cpython-36.pyc
0045_auto__add_plugins.cpython-36.pyc
0046_auto__add_field_plugins_jail_interface.cpython-36.pyc
0047_auto__add_field_cifs_cifs_srv_unixext.cpython-36.pyc
0048_auto__chg_field_snmp_snmp_location.cpython-36.pyc
0049_auto__chg_field_tftp_tftp_directory.cpython-36.pyc
0050_auto__add_field_ssh_ssh_host_ecdsa_key__add_field_ssh_ssh_host_ecdsa_k.cpython-36.pyc
0051_auto__del_field_afp_afp_srv_local.cpython-36.pyc
0053_auto__add_field_cifs_cifs_srv_zeroconf.cpython-36.pyc
0054_auto__chg_field_ftp_ftp_masqaddress.cpython-36.pyc
0055_auto__del_field_plugins_jail_netmask__del_field_plugins_jail_interface.cpython-36.pyc
0056_auto__add_iscsitargetportalip__add_unique_iscsitargetportalip_iscsi_ta.cpython-36.pyc
0057_auto__del_field_iscsitargetportal_iscsi_target_portal_listen.cpython-36.pyc
0058_auto__add_field_cifs_cifs_srv_homedir_aux__chg_field_cifs_cifs_srv_smb.cpython-36.pyc
0059_auto__chg_field_plugins_jail_path__chg_field_plugins_plugins_path.cpython-36.pyc
0060_auto__del_field_cifs_cifs_srv_guestok__del_field_cifs_cifs_srv_gueston.cpython-36.pyc
0061_auto__chg_field_iscsitargetglobalconfiguration_iscsi_luc_authnetwork.cpython-36.pyc
0062_auto__add_rpctoken.cpython-36.pyc
0063_auto__chg_field_plugins_jail_ip.cpython-36.pyc
0064_rename_plugins_pluginsjail.cpython-36.pyc
0065_auto__del_field_rpctoken_last_used__del_field_rpctoken_token__add_fiel.cpython-36.pyc
0066_auto__add_field_pluginsjail_jail_ipv4address__add_field_pluginsjail_ja.cpython-36.pyc
0067_auto__del_field_pluginsjail_jail_ip.cpython-36.pyc
0068_auto__chg_field_iscsitargetglobalconfiguration_iscsi_lucip.cpython-36.pyc
0068_auto__del_field_nfs_nfs_srv_async.cpython-36.pyc
0069_auto__add_field_cifs_cifs_srv_hostlookup.cpython-36.pyc
0070_auto__del_field_activedirectory_ad_dcname.cpython-36.pyc
0071_auto__add_field_ftp_ftp_ssltls_certfile.cpython-36.pyc
0072_auto__add_field_activedirectory_ad_use_default_domain.cpython-36.pyc
0073_auto__add_field_activedirectory_ad_verbose_logging.cpython-36.pyc
0074_auto__add_field_activedirectory_ad_unix_extensions.cpython-36.pyc
0075_auto__add_field_nfs_nfs_srv_allow_nonroot__add_field_nfs_nfs_srv_bindi.cpython-36.pyc
0076_auto__add_field_pluginsjail_jail_mac.cpython-36.pyc
0077_auto__add_field_ssh_ssh_sftp_log_level__add_field_ssh_ssh_sftp_log_fac.cpython-36.pyc
0078_smart_email_comma.cpython-36.pyc
0079_auto__add_field_activedirectory_ad_dchost__add_field_activedirectory_a.cpython-36.pyc
0080_auto__del_field_activedirectory_ad_dchost__del_field_activedirectory_a.cpython-36.pyc
0081_auto__add_field_activedirectory_ad_dns_timeout.cpython-36.pyc
0082_auto__add_nis__add_nt4.cpython-36.pyc
0083_auto__add_field_nt4_nt4_hostname.cpython-36.pyc
0084_auto__del_field_nt4_nt4_hostname__add_field_nt4_nt4_dcname.cpython-36.pyc
0085_auto__add_field_nis_nis_servers__add_field_nis_nis_secure_mode__add_fi.cpython-36.pyc
0086_default_ups.cpython-36.pyc
0087_auto__del_field_cifs_cifs_srv_largerw.cpython-36.pyc
0088_auto__add_field_ups_ups_mode__add_field_ups_ups_remotehost__add_field_.cpython-36.pyc
0089_auto__del_pluginsjail.cpython-36.pyc
0090_auto__add_field_nfs_nfs_srv_mountd_port__add_field_nfs_nfs_srv_rpcstat.cpython-36.pyc
0091_auto__del_field_smart_smart_informal__add_field_smart_smart_informatio.cpython-36.pyc
0092_auto__rename_field_ftp_ftp_ssltls__to__ftp_ftp_tls.cpython-36.pyc
0093_auto__del_field_cifs_cifs_srv_sendfile.cpython-36.pyc
0094_auto__chg_field_ups_ups_shutdowntimer.cpython-36.pyc
0095_add_nis_nt4_entries.cpython-36.pyc
0096_auto__del_field_afp_afp_srv_name.cpython-36.pyc
0097_auto__add_field_ftp_ftp_tls_policy__add_field_ftp_ftp_tls_opt_allow_cl.cpython-36.pyc
0098_auto__add_field_afp_afp_srv_homedir_enable__add_field_afp_afp_srv_home.cpython-36.pyc
0099_auto__del_field_activedirectory_ad_adminname__del_field_activedirector.cpython-36.pyc
0100_auto__add_domaincontroller.cpython-36.pyc
0101_del_activedirectory_from_services.cpython-36.pyc
0102_auto__add_field_nfs_nfs_srv_udp.cpython-36.pyc
0103_auto__add_field_domaincontroller_dc_storage.cpython-36.pyc
0104_auto__del_field_domaincontroller_dc_storage.cpython-36.pyc
0105_auto__add_field_cifs_cifs_srv_min_protocol__add_field_cifs_cifs_srv_ma.cpython-36.pyc
0106_auto__del_field_cifs_cifs_srv_authmodel.cpython-36.pyc
0107_iscsitargetglobalconfiguration_iscsi_discoveryauthgroup.cpython-36.pyc
0108_auto__add_field_cifs_cifs_srv_syslog.cpython-36.pyc
0109_auto__add_field_dynamicdns_ddns_ipserver.cpython-36.pyc
0110_auto__add_field_cifs_cifs_srv_allow_execute_always.cpython-36.pyc
0111_ldap_tls_cacertfile.cpython-36.pyc
0112_auto__add_field_iscsitargettoextent_iscsi_lunid.cpython-36.pyc
0113_auto__add_field_iscsitargetglobalconfiguration_iscsi_multithreaded.cpython-36.pyc
0114_auto__add_lldp.cpython-36.pyc
0115_auto__add_field_afp_afp_srv_dbpath.cpython-36.pyc
0116_auto__chg_field_afp_afp_srv_dbpath.cpython-36.pyc
0117_auto__del_field_cifs_cifs_srv_easupport__del_field_cifs_cifs_srv_dosat.cpython-36.pyc
0118_auto__add_field_cifs_cifs_srv_domain_logons.cpython-36.pyc
0119_auto__add_field_iscsitargetglobalconfiguration_iscsi_experimental.cpython-36.pyc
0120_nfs_srv_allow_nonroot.cpython-36.pyc
0121_auto__add_field_activedirectory_ad_ssl.cpython-36.pyc
0121_change_AD_advanced_fields.cpython-36.pyc
0122_add_field_ActiveDirectory_ad_nss_info.cpython-36.pyc
0122_auto__add_field_activedirectory_ad_certfile.cpython-36.pyc
0122_auto__add_field_cifs_cifs_srv_bindip.cpython-36.pyc
0123_auto__del_field_activedirectory_ad_workgroup.cpython-36.pyc
0124_remove_directoryservice.cpython-36.pyc
0125_auto__del_activedirectory__del_nis__del_nt4__del_ldap.cpython-36.pyc
0126_auto__add_field_cifs_cifs_srv_obey_pam_restrictions.cpython-36.pyc
0127_auto__add_field_iscsitargetextent_iscsi_target_extent_naa__add_field_i.cpython-36.pyc
0128_naa.cpython-36.pyc
0129_auto__add_unique_iscsitargetextent_iscsi_target_extent_naa.cpython-36.pyc
0130_auto__del_field_iscsitargetglobalconfiguration_iscsi_experimental_targ.cpython-36.pyc
0131_auto__del_field_iscsitarget_iscsi_target_queue_depth__del_field_iscsit.cpython-36.pyc
0132_auto__chg_field_iscsitarget_iscsi_target_logical_blocksize.cpython-36.pyc
0133_auto__add_field_nfs_nfs_srv_v4.cpython-36.pyc
0134_convertnfsv4hacktodatabase.cpython-36.pyc
0135_auto__add_field_nfs_nfs_srv_v4_root.cpython-36.pyc
0136_auto__del_field_nfs_nfs_srv_v4_root.cpython-36.pyc
0137_auto__add_field_domaincontroller_dc_kerberos_realm.cpython-36.pyc
0138_add_domaincontroller_kerberos_realm.cpython-36.pyc
0139_auto__add_webdav.cpython-36.pyc
0139_auto__chg_field_domaincontroller_dc_kerberos_realm.cpython-36.pyc
0140_auto__chg_field_iscsitarget_iscsi_target_initiatorgroup.cpython-36.pyc
0140_manual_add_webdav_to_services_db.cpython-36.pyc
0141_auto__chg_field_domaincontroller_dc_kerberos_realm.cpython-36.pyc
0142_auto__add_field_cifs_cifs_SID.cpython-36.pyc
0143_add_smart.cpython-36.pyc
0144_auto__add_field_afp_afp_srv_global_aux.cpython-36.pyc
0145_auto__del_field_ftp_ftp_ssltls_certfile__add_field_ftp_ftp_ssltls_cert.cpython-36.pyc
0146_auto__del_field_ftp_ftp_tls_opt_use_implicit_ssl.cpython-36.pyc
0147_auto__add_field_cifs_cifs_srv_bindip.cpython-36.pyc
0148_auto__del_field_cifs_cifs_srv_homedir_enable__del_field_cifs_cifs_srv_.cpython-36.pyc
0149_auto__add_field_afp_afp_srv_bindip.cpython-36.pyc
0150_autotonone.cpython-36.pyc
0151_auto__add_field_webdav_webdav_certssl.cpython-36.pyc
0152_auto__add_field_iscsitargetglobalconfiguration_iscsi_isns_servers.cpython-36.pyc
0153_auto__add_field_iscsitargetextent_iscsi_target_extent_avail_threshold_.cpython-36.pyc
0154_auto__add_field_ssh_ssh_host_ed25519_key__add_field_ssh_ssh_host_ed255.cpython-36.pyc
0154_auto__chg_field_iscsitargetextent_iscsi_target_extent_naa.cpython-36.pyc
0155_auto__add_field_iscsitargetextent_iscsi_target_extent_xen.cpython-36.pyc
0156_auto__add_field_iscsitargetextent_iscsi_target_extent_blocksize__add_f.cpython-36.pyc
0157_auto__del_field_iscsitarget_iscsi_target_logical_blocksize.cpython-36.pyc
0158_auto__add_field_afp_afp_srv_homename.cpython-36.pyc
0159_auto__add_field_nfs_nfs_srv_v4_krb.cpython-36.pyc
0160_pwencrypt.cpython-36.pyc
0161_auto__chg_field_cifs_cifs_srv_bindip.cpython-36.pyc
0162_auto__add_field_iscsitargetextent_iscsi_target_extent_rpm.cpython-36.pyc
0163_auto__add_field_ssh_ssh_host_dsa_key_cert_pub__add_field_ssh_ssh_host_.cpython-36.pyc
0164_nfs_srv_v4_krb_fix.cpython-36.pyc
0165_auto__add_field_snmp_snmp_v3__add_field_snmp_snmp_v3_username__add_fie.cpython-36.pyc
0166_pwencrypt.cpython-36.pyc
0167_auto__add_field_ups_ups_powerdown.cpython-36.pyc
0168_snmp_v3_literal.cpython-36.pyc
0169_auto__add_field_iscsitargetportal_iscsi_target_portal_discoveryauthmet.cpython-36.pyc
0170_copy_discovery_fields.cpython-36.pyc
0171_auto__del_field_iscsitargetglobalconfiguration_iscsi_discoveryauthmeth.cpython-36.pyc
0172_auto__add_field_iscsitargetextent_iscsi_target_extent_serial.cpython-36.pyc
0173_auto__del_field_iscsitarget_iscsi_target_serial.cpython-36.pyc
0174_auto__add_iscsitargetgroups.cpython-36.pyc
0175_target_to_groups.cpython-36.pyc
0176_auto__del_field_iscsitarget_iscsi_target_portalgroup__del_field_iscsit.cpython-36.pyc
0177_auto__del_field_iscsitargetgroups_iscsi_target_type.cpython-36.pyc
0178_auto__add_fiberchanneltotarget.cpython-36.pyc
0179_auto__add_field_iscsitarget_iscsi_target_mode.cpython-36.pyc
0180_auto__del_unique_iscsitargettoextent_iscsi_extent__add_unique_iscsitar.cpython-36.pyc
0181_auto__add_field_snmp_snmp_v3_authtype__add_field_snmp_snmp_v3_privprot.cpython-36.pyc
0182_auto__add_unique_iscsitargetgroups_iscsi_target_iscsi_target_portalgro.cpython-36.pyc
0183_auto__chg_field_fiberchanneltotarget_fc_target.cpython-36.pyc
0184_auto__del_fiberchanneltotarget__add_fibrechanneltotarget.cpython-36.pyc
0185_auto__add_field_iscsitargetextent_iscsi_target_extent_ro.cpython-36.pyc
0186_auto__add_field_ssh_ssh_kerberosauth.cpython-36.pyc
0187_auto__add_field_nfs_nfs_srv_16.cpython-36.pyc
0188_auto__add_field_ssh_ssh_bindiface.cpython-36.pyc
0189_auto__add_field_nfs_nfs_srv_v4_v3owner.cpython-36.pyc
0190_dup_webdav.cpython-36.pyc
0191_auto__add_field_cifs_cifs_srv_netbiosname_b__add_field_cifs_cifs_srv_n.cpython-36.pyc
0192_netbiosname_split.cpython-36.pyc
0193_auto__add_field_iscsitargetextent_iscsi_target_extent_legacy.cpython-36.pyc
0194_auto__add_field_ups_ups_optionsupsd.cpython-36.pyc
0195_auto__add_field_nfs_nfs_srv_mountd_log__add_field_nfs_nfs_srv_statd_lo.cpython-36.pyc
0196_auto__add_field_services_ups_ups_shutdowncmd.cpython-36.pyc
0197_add_field_AFP_afp_srv_map_acls.cpython-36.pyc
0198_iscsi_expunge_lun_auto.cpython-36.pyc
0199_auto__add_field_iscsitargetglobalconfiguration_iscsi_alua.cpython-36.pyc
0200_remove_obsolete_services.cpython-36.pyc
