warriorcookie
- Apr 17, 2017
So FreeNAS sent me an error saying the administrator had taken DA5 offline and the pool was degraded. I'm the only admin, and I definitly didn't do that....
So I looked at the disk listing and DA5 was missing. I removed it from it's bay and re-inserted and no change. I moved it down to an empty bay, refreshed the list of disks by the web interface stopped responding. So I reboot, all disks are now showing, but when I try unlocking the pool I get the following error in one big run on string:
So I shutdown, put the DA5 drive back in its original bay. Startup, unlock and now the error has changed:
I've tried unlocking with the key file and it gives the same error.
Not sure what happened, or what I did wrong.
What would you suggest I do next? Should I try detaching them import?
Environment: Software Version: FreeNAS-11.0-U2 (e417d8aa5) Request Method: POST Request URL: http://freenas.bailey.com/storage/volume/2/unlock/?X-Progress-ID=e9a87134-7833-4168-886b-ae68e9363a3c Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in volume_unlock 1190. form.done(volume=volume) File "./freenasUI/storage/forms.py" in done 2616. raise MiddlewareError(msg) Exception Type: MiddlewareError at /storage/volume/2/unlock/ Exception Value: [MiddlewareError: b'Volume could not be imported']
Environment: Software Version: FreeNAS-11.0-U2 (e417d8aa5) Request Method: POST Request URL: http://freenas.bailey.com/storage/volume/2/unlock/?X-Progress-ID=f0e7ee20-d55f-4286-8191-f9ae2cf25849 Traceback: File "/usr/local/lib/python3.6/site-packages/django/core/handlers/exception.py" in inner 39. response = get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _legacy_get_response 249. response = self._get_response(request) File "/usr/local/lib/python3.6/site-packages/django/core/handlers/base.py" in _get_response 178. response = middleware_method(request, callback, callback_args, callback_kwargs) File "./freenasUI/freeadmin/middleware.py" in process_view 162. return login_required(view_func)(request, *view_args, **view_kwargs) File "/usr/local/lib/python3.6/site-packages/django/contrib/auth/decorators.py" in _wrapped_view 23. return view_func(request, *args, **kwargs) File "./freenasUI/storage/views.py" in volume_unlock 1190. form.done(volume=volume) File "./freenasUI/storage/forms.py" in done 2616. raise MiddlewareError(msg) Exception Type: MiddlewareError at /storage/volume/2/unlock/ Exception Value: [MiddlewareError: b'Volume could not be imported: 2 devices failed to decrypt']
