Error when creating Jail
nearbyatom
I was following the tutorial to creating a Plex Jail written by Cosmo Kramer. I got to the part where it says "Add Jail". I followed the instructions, click OK. Then I get the error below.
[warden_exception: fetch: http://download.freenas.org/jails/11/x64/freenas-standard-11.0-RELEASE.mtree: No address record http://download.freenas.org/jails/11/x64/freenas-standard-11.0-RELEASE.tgz: No address record mtree: /mnt/Server/Jail/.warden-files-cache/mtree/freenas-standard-11.0-RELEASE.mtree: No such file or directory ERROR: mtree failed for /mnt/Server/Jail/.warden-files-cache/mtree/freenas-standard-11.0-RELEASE.mtree cannot open 'Server/Jail/.warden-template-standard': dataset does not exist find: /mnt/Server/Jail/.warden-template-standard: No such file or directory ERROR: Failed to create ZFS base dataset ]
I created the ZFS data set already (see attached). It's called Jail.
Where did I go wrong?
mozzi20
Can you try to ping download.freenas.org from that machine? It looks like a fresh install but have you changed any of the settings?
Jailer
Not strong, but bad
Did you set your jail root by selecting your jail template from the jails -> configuration tab?
