SOLVED Error "truenas ntpd[999]: error resolving pool 0.freebsd.pool.ntp.org: name does not resolve (8)"
Heracles
You can re-install the system and it will not touch the pool. Of course, do not install the system over one of the data drive for that... Just re-install over the same boot device and the new system will be able to import the pool. That is if you did not used pool-level encryption.
If you did use encryption, extract all your data from that pool first. Encryption is way beyond your reach and you will end up with a self-inflicted ransomware instead of a security feature.
How do I check if I didn't use pool level encryption? Do I also need to put the settings manually?
Heracles
Considering how low we are right now and that you confirmed you do not have any sensitive data in that server for now, I would recommend you just destroy everything and re-start from scratch...
I did also take a backup of the NAS in the .tar file just incase if anything goes wrong so can I restore will that? Can I use a different type of operating system such as TrueNAS Scale? What are the benefits of doing that like do I get my plugins back and configuration back?
Anyways I got it! What I did was I just re-installed TrueNAS and uploaded my config file and it is up and running! I got my data back but I need to reinstall the plugins. Thank you so much for the help!
