Error replacing disc
mon39
1 out of 5 of my disk became unavailable. Took it out and replace with another good one and another (tried 2 hdd), also changed sata cable, sata port. I offline the unavailable disk before taking it out and clicked force replaced on new disk. Still failed :( I've run long smart test on those 2 replacement hdd on another machine and they are fine.
Error: Traceback (most recent call last): File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run await self.future File "/usr/lib/python3/dist-packages/middlewared/job.py", line 446, in __run_body rv = await self.method(*([self] + args)) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf return await func(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf res = await f(*args, **kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/replace_disk.py", line 93, in replace await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1345, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call return await methodobj(*prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks await asyncio_map(format_disk, disks.items(), limit=16) File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map return await asyncio.gather(*futures) File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 13, in func return await real_func(arg) File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk await self.middleware.call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1345, in call return await self._call( File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1305, in _call return await self.run_in_executor(prepared_call.executor, methodobj, *prepared_call.args) File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs)) File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run result = self.fn(*self.args, **self.kwargs) File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 68, in format raise CallError(f'Unable to GPT format the disk "{disk}": {cp.stderr}') middlewared.service_exception.CallError: [EFAULT] Unable to GPT format the disk "sdf": Problem opening /dev/sdf for reading! Error is 2. The specified file does not exist!
