adieljulio
- Oct 3, 2022
I just setup TrueNAS Scale today. I want to create a pool with intel optane as l2arc cache. but when I create, I got error
I already tried manually creating a GPT table and partition using
The setup:
- CPU: Intel(R) Core(TM) i7-12700
- Motherboard: Biostar B660GTN
- 64 GB RAM (2x32GB)
- Intel Optane 16GB
- JMB585 5x sata to M.2
- 2x Seagate Ironwolf NAS 10TB
TrueNAS-SCALE-22.02.4
[EFAULT] Failed to wipe disk nvme0n1: [Errno 16] Device or resource busy: '/dev/nvme0n1'
.I already tried manually creating a GPT table and partition using
parted
it was a success. but when using GUI pool it failed. here is the error callstack of the GUIError: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 446, in __run_body
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1140, in nf
res = await f(*args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1272, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool.py", line 740, in do_create
await self.middleware.call('pool.format_disks', job, disks)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1345, in call
return await self._call(
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1294, in _call
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 56, in format_disks
await asyncio_map(format_disk, disks.items(), limit=16)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 16, in asyncio_map
return await asyncio.gather(*futures)
File "/usr/lib/python3/dist-packages/middlewared/utils/asyncio_.py", line 13, in func
return await real_func(arg)
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool_/format_disks.py", line 29, in format_disk
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1305, in _call
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1206, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk_/format.py", line 26, in format
raise CallError(f'Failed to wipe disk {disk}: {job.error}')
middlewared.service_exception.CallError: [EFAULT] Failed to wipe disk nvme0n1: [Errno 16] Device or resource busy: '/dev/nvme0n1'
The setup:
- Intel Optane 16GB
