Hello all!
I just installed TrueNAS SCALE 22.02.2.1 to try to get things up and running. It's installed on bare metal with default options. Before changing any settings, I was clicking around and got the following error trying to open the Official catalog:
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 411, in run
await self.future
File "/usr/lib/python3/dist-packages/middlewared/job.py", line 448, in __run_body
rv = await self.middleware.run_in_thread(self.method, *([self] + args))
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1208, in run_in_thread
return await self.run_in_executor(self.thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1205, in run_in_executor
File "/usr/lib/python3.9/concurrent/futures/thread.py", line 52, in run
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1268, in nf
args, kwargs = clean_and_validate_args(args, kwargs)
File "/usr/lib/python3/dist-packages/middlewared/schema.py", line 1258, in clean_and_validate_args
raise verrors
middlewared.service_exception.ValidationErrors: [EINVAL] options.retrieve_versions: Field was not expected
I looked through the logs, but don't see anything besides the middleware error that is displayed in the UI as well.
I tried adding another catalog (TrueCharts) and it's exhibiting the same behavior. I tried reinstalling TrueNAS just to make sure something didn't go wrong during install, but no luck.
Anyone run into this?
Thanks!
await self.future
raise verrors
Thanks!
