Error message? WRITE_FPDMA_QUEUED
eddie200112
What does this error message mean?
freenas.local kernel log messages:
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 08 e4 a0 40 00 00 00 00 00 00
-- End of security output --
eddie200112
No all my drives are either western digital black or Seagate 4tb drives
eddie200112
Got the message again. No one have any idea what this means? Im afraid this might mean one of my drives is close to failing is that correct?
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 18 90 15 3c 40 8d 00 00 00 00 00
JDCynical
eddie200112
OK seems to be getting worse I got a much longer error last night as I was moving data ont the FreeNAS.
So I'm going to just assume that its likely a bad disk first. So then how do I tell which physical disk it is? Maybe someway it can pull up the drive model and serial? Is there an easy way to go about that? Also is there a way to see the SMART test results of this drive (ada5) and help determine if there is in fact a problem with that drive?
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 50 a6 34 40 90 00 00 01 00 00
> (ada5:ahcich7:0:0:0): CAM status: Uncorrectable parity/CRC error
> (ada5:ahcich7:0:0:0): Retrying command
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 90 74 37 40 90 00 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 50 46 38 40 90 00 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 50 f6 3d 40 90 00 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 b8 f5 2f 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 d0 01 37 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 c8 18 a7 37 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 98 50 4a 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 20 5c 4a 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 10 80 bd 5a 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 08 23 64 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 80 8a 64 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 38 d4 65 40 33 01 00 01 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 d0 88 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 10 89 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 50 89 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 d0 89 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 90 89 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 10 8a 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 50 8a 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 90 8a 6c 40 33 01 00 00 00 00
> (ada5:ahcich7:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 40 d0 8a 6c
joeschmuck
Old Man
eddie200112
Model Family: Western Digital Black
Device Model: WDC WD4003FZEX-00Z4SA0
Serial Number: WD-WMC5D0D41JZ8
LU WWN Device Id: 5 0014ee 05943ce57
Firmware Version: 01.01A01
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sat Mar 19 10:12:46 2016 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x85) Offline data collection activity
was aborted by an interrupting command from host.
been run.
data collection: (43440) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 470) minutes.
joeschmuck
Old Man
Post the entire output of "smartctl -a /dev/ada5" in code brackets (use the newspaper icon to the left of the floppy disk icon when posting and select code). What you posted above means nothing to help out with this problem other than it takes 470 minutes (almost 8 hours) to run an extended test. Hopefully you have been running routine SMART testing so there will be some data to look at now.
eddie200112
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x7035) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 163 156 021 Pre-fail Always - 10850
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 15
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8106
10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 15
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 4
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 10
194 Temperature_Celsius 0x0022 126 113 000 Old_age Always - 26
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 8050 -
# 2 Short offline Completed without error 00% 7859 -
# 3 Extended offline Interrupted (host reset) 50% 7765 -
# 4 Short offline Completed without error 00% 7667 -
# 5 Short offline Completed without error 00% 7547 -
# 6 Short offline Completed without error 00% 7451 -
# 7 Short offline Completed without error 00% 7355 -
# 8 Short offline Completed without error 00% 7163 -
# 9 Extended offline Completed without error 00% 7075 -
#10 Short offline Completed without error 00% 6972 -
#11 Short offline Completed without error 00% 6804 -
#12 Short offline Completed without error 00% 6708 -
#13 Short offline Completed without error 00% 6612 -
#14 Short offline Completed without error 00% 6420 -
#15 Extended offline Completed without error 00% 6332 -
#16 Short offline Completed without error 00% 6128 -
#17 Short offline Completed without error 00% 6033 -
#18 Short offline Completed without error 00% 5937
#18 Short offline Completed without error 00% 5937 -
#19 Short offline Completed without error 00% 5745 -
#20 Extended offline Interrupted (host reset) 70% 5650 -
#21 Short offline Completed without error 00% 5553 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
eddie200112
Sorry had the rest but got distracted
Mirfster
Code tags hint:
index.php
eddie200112
No Errors Logged
If Selective self-test is pending on power-up, resume after 0 minute
eddie200112
Local Time is:    Sat Mar 19 12:00:19 2016 CDT
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   089   089   000    Old_age   Always       -       8107
No Errors Logged
joeschmuck
Old Man
Assuming the drive you posted was ada5, there is nothing wrong with it, no indications of a failure. I would have expected ID 199 to have some value other than zero. This leads me to thinking the controller or SATA cable is suspect. My guide should have had you replace or swap around SATA cables for the ada5 drive, this will not change ada5, just the cable it interfaces with the controller. Have you done that. Please follow the guide completely and then report back either that you found the issue or if you cannot figure it out, report what step of the guide failed. If you do everything as expected, I doubt you will post about this problem today as this could take some time to isolate.
eddie200112
Do SATA cables really just go bad? Ive had the system running for a year with no problems and haven't moved it or anything.. but ill still give it a shot
eddie200112
OK cable is replaced. Do I just make the drive run a long test and see if I get the error again? Or do I try to transfer data to it?
joeschmuck
Old Man
I too had a hard time swallowing that but yes, some cables are not as good as others and they just don't work as well. I think it could be noise rejection issues, grounding issues, loose connectors, or just cheap plated connections.
SMART tests are internal to the drive so those will not tell you if you have fixed a cable problem. If you want to try to force it I'd scrub the pool as this will result in a lot of data traffic. If you swapped the data cable between drives then look to see if the problem remains with the suspect drive (always use the serial number to identify and track it). If you just replaced the cable, maybe the problem is gone. And to be honest, it could take you a few weeks before you consider the problem fixed if you replaced a part and the problem stops because it wasn't 100% constant.
eddie200112
Forced a scrub. So far so good. Worth noting the cable was a bit loose/crooked when I replaced it, so hopefully that was it. Thanks for the help!
