I've just started the replacement process on a WD green drive to a red that had 2 to offlined sectors from a SMART test. The relsilvering is in progress but now I am getting parity CRC errors again. I didn't have these on the old drive, now all of a sudden as soon as I swap out the drive I'm getting heaps of them. 1st question, is this a problem? At the moment I'm going to let the re-silvering process complete first. 2nd question where to from here? I think it's time to get a sata card rather then using the onboard ports. I've had these errors in the past and solved it by changing ports and cables.
Here is the zpool status of the resilvering process:-
And here is the errors i'm seeing in the GUI shell in the footer...
[root@freenas ~]# zpool status
pool: NAS
state: DEGRADED
status: One or more devices is currently being resilvered. The pool will
continue to function, possibly in a degraded state.
action: Wait for the resilver to complete.
scan: resilver in progress since Mon May 12 11:41:51 2014
163G scanned out of 9.81T at 158M/s, 17h46m to go
32.6G resilvered, 1.62% done
NAME STATE READ WRITE CKSUM
NAS DEGRADED 0 0 0
raidz1-0 DEGRADED 0 0 0
gptid/71cbb176-bcb1-11e1-aa48-c8600014c8a1 ONLINE 0 0 0
gptid/7266b6e7-bcb1-11e1-aa48-c8600014c8a1 ONLINE 0 0 0
gptid/72f9c4f5-bcb1-11e1-aa48-c8600014c8a1 ONLINE 0 0 0
gptid/738c5264-bcb1-11e1-aa48-c8600014c8a1 ONLINE 0 0 0
replacing-4 OFFLINE 0 0 0
6054011502170042877 OFFLINE 0 0 0 was /dev/gptid/74228c86-bcb1-11e1-aa48-c860001
4c8a1
gptid/96cee5b7-d976-11e3-86e0-3085a9a218e2 ONLINE 0 0 0 (resilvering)
errors: No known data errors
[root@freenas ~]# And here is the errors i'm seeing in the GUI shell in the footer...
May 12 12:05:26 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:26 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:26 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 28 14 87 40 5b 00 00 01 00 00 May 12 12:05:26 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:26 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 a8 2f 87 40 5b 00 00 01 00 00 May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 68 50 87 40 5b 00 00 01 00 00 May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 68 72 87 40 5b 00 00 01 00 00 May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:27 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 68 7f 87 40 5b 00 00 01 00 00 May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 68 94 87 40 5b 00 00 01 00 00 May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:28 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 a8 29 98 40 5b 00 00 01 00 00 May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 a8 5d 98 40 5b 00 00 01 00 00 May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:29 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command May 12 12:05:30 freenas kernel: (ada4:ahcich5:0:0:0): WRITE_FPDMA_QUEUED. ACB: 61 00 a8 13 9a 40 5b 00 00 01 00 00 May 12 12:05:30 freenas kernel: (ada4:ahcich5:0:0:0): CAM status: Uncorrectable parity/CRC error May 12 12:05:30 freenas kernel: (ada4:ahcich5:0:0:0): Retrying command
