An error occurs (regular and manual) (below log)
[EFAULT] Cannot remove file /usr/local/www/dojo/dijit/nls/zh/common.js
FAILED
FAILED
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 649, in do_update
    if ApplyUpdate(dest_extracted) is None:
  File "/usr/local/lib/freenasOS/Update.py", line 1627, in ApplyUpdate
    raise e
  File "/usr/local/lib/freenasOS/Update.py", line 1559, in ApplyUpdate
    if installer.InstallPackages(progressFunc=progressFunc, handler=install_handler) is False:
  File "/usr/local/lib/freenasOS/Installer.py", line 1088, in InstallPackages
    trampoline=self.trampoline) is False:
  File "/usr/local/lib/freenasOS/Installer.py", line 823, in install_file
    if pkgdb.RemovePackageFiles(pkgName) == False:
  File "/usr/local/lib/freenasOS/Configuration.py", line 347, in RemovePackageFiles
    raise Exception("Cannot remove file %s" % path)
Exception: Cannot remove file /usr/local/www/dojo/dijit/nls/zh/common.js
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 349, in run
    await self.future
  File "/usr/local/lib/python3.7/site-packages/middlewared/job.py", line 386, in __run_body
  File "/usr/local/lib/python3.7/site-packages/middlewared/schema.py", line 961, in nf
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 654, in file
    await self.middleware.run_in_thread(do_update)
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/run_in_thread.py", line 10, in run_in_thread
    return await self.loop.run_in_executor(self.run_in_thread_executor, functools.partial(method, *args, **kwargs))
  File "/usr/local/lib/python3.7/site-packages/middlewared/utils/io_thread_pool_executor.py", line 25, in run
  File "/usr/local/lib/python3.7/site-packages/middlewared/plugins/update.py", line 652, in do_update
    raise CallError(str(e))
middlewared.service_exception.CallError: [EFAULT] Cannot remove file /usr/local/www/dojo/dijit/nls/zh/common.js
