Hello, I recently created a Ubuntu 18.04.03 VM with a VirtIO disk and networking. It is in the folder
The disk is called was automatically named as a zvol in as
The permissions for virtual and virtual/fn are
When I hit the clone button (3 dots --> Clone) I receive the following error:
Any idea what is going on?
I was hoping to clone the initial install to make spinning up new machines easy.
/mnt/tank1/ds1/virtual/fn/
virtual/fn/Ubuntu_Full_Node-hhrpo
nobody:virtual 770
.When I hit the clone button (3 dots --> Clone) I receive the following error:
[ENOENT] vm_create.devices.1.attributes.path: Disk path /dev/zvol/tank1/ds1/virtual/fn/Ubuntu_Full_Node-hhrpo_Ubuntu_Full_Node_clone0 does not exist. Error: Traceback (most recent call last): File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 165, in call_method result = await self.middleware.call_method(self, message) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1107, in call_method return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False) File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1055, in _call return await methodobj(*args) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1436, in clone raise e File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1419, in clone await self.create(vm) File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 290, in create f'{self._config.namespace}.create', self, self.do_create, [data] File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1055, in _call return await methodobj(*args) File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf return await f(*args, **kwargs) File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 963, in do_create raise verrors middlewared.service_exception.ValidationErrors: [ENOENT] vm_create.devices.1.attributes.path: Disk path /dev/zvol/tank1/ds1/virtual/fn/Ubuntu_Full_Node-hhrpo_Ubuntu_Full_Node_clone0 does not exist.
