skullitor13
- Oct 28, 2018
So when I attempt to create a new VM using the UI I get the following error:
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 161, in call_method
result = await self.middleware.call_method(self, message)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1109, in call_method
return await self._call(message['method'], serviceobj, methodobj, params, app=app, io_thread=False)
File "/usr/local/lib/python3.6/site-packages/middlewared/main.py", line 1049, in _call
return await methodobj(*args)
File "/usr/local/lib/python3.6/site-packages/middlewared/service.py", line 278, in create
f'{self._config.namespace}.create', self, self.do_create, [data]
File "/usr/local/lib/python3.6/site-packages/middlewared/schema.py", line 664, in nf
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 956, in do_create
raise verrors
middlewared.service_exception.ValidationErrors: [EINVAL] vm_create.vcpus: Only one Virtual CPU is allowed in this system.
It will let me create a VM with only one CPU but it won't start and gives me the error:
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 1132, in start
await self._manager.start(vm)
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 61, in start
list(done)[0].result()
File "/usr/local/lib/python3.6/site-packages/middlewared/plugins/vm.py", line 315, in run
raise CallError(f'VM {self.vm["name"]} failed to start: {output}')
middlewared.service_exception.CallError: [EFAULT] VM NVR failed to start: vm_create: Device not configured
Is this some sort of hardware compatibility issue?
I am running a AMD 2700X.
Let me know if you need more information and thanks for any help.
raise verrors
