Error after installing GNOME
bienio
I tried install Gnome and after restart I have no IP from DHCP and so on error in message:
error resolving pool 0.freebsd.pool.ntp.org
I can't even startX.
I put in rc.conf
line
ifconfig_lagg0="DHCP"
and restarted by
service netif restart
no ping respond locally..
Samuel Tai
Where did you try to install GNOME? Inside a jail, or on the base OS?
Samuel Tai
Why would you do that? FreeNAS is a highly stripped-down version of FreeBSD dedicated to storage. Furthermore, it actively overwrites system files, like rc.conf, based on its settings in the system database, so various settings GNOME needs are now lost. You’re going to have to reinstall the base OS.
John Doe
have you already tried to turn it off and on again?
bienio
I thought it will work with no issues as other linux distros I wanted to have emulation installed. Ok now I know where I stuck. Thanks
Patrick M. Hausen
FreeNAS is an embedded solution. One does not simply install anything on the base OS. A NAS is supposed to be a device sitting in a rack or in my case at home in a cupboard. I wonder why anyone would want a graphical environment on it. Mine do not even have monitors and keyboards attached.
So if you would elaborate on your use case a bit, we could possibly suggest some suitable setups. ;)
bienio
What I wanted done was to run gnome for emulation. Intead run always weak VM I will install ubuntu now. Thanks!
Patrick M. Hausen
I do not see how gnome has any relationship to emulation, but probably FreeNAS was the wrong product for you.
Samuel Tai
I think I understand @bienio's intent. GNOME has an application, Boxes, for managing both VMs and remote servers. He may have been trying to use Boxes to manage bhyve VMs instead of the web GUI. Unfortunately, Boxes relies on KVM and libvirt, not bhyve. FreeBSD unfortunately can't use KVM as a hypervisor, and libvirt is very limited on FreeBSD.
