ERR_TOO_MANY_REDIRECTS erro after Nexcloud 20.0.4 Plugin Install
jpatel
Hello everyone,
I am not sure if this issue is there for the plugin update, but I just finished installing NextCloud Plugin (Version 20.0.4) and I have added the entry of my domain into trusted_domains. I can successfully see the login page, but once I hit I login with valid credentials, the browser shows me ERR_TOO_MANY_REDIRECTS error with message "nextcloud.domain.com redirected you too many times."
It keeps trying to redirect to /apps/files uri. When I checked /usr/local/www/nextcloud/apps, it was empty. I saw there is a new directory called apps_pkg with apps and tried to change the configuration to point to that directory, but after that, I started getting "Gateway timeout error"
Here is my new config to point to the new app directory (getting 504 Gateway timeout with below config).
"apps_paths" => array(
0 => array(
‘path’ => ‘/usr/local/www/nextcloud/apps-pkg’,
‘url’ => ‘/apps-pkg’,
‘writable’ => true,
Can anyone please help me here?
rasalone
I have the same issue. After login I land on /apps/files/ but that dir is empty. Here is the plug in install log.
Install Notes:
nginx_enable: -> YES
mysql_enable: -> YES
php_fpm_enable: -> YES
Performing sanity check on nginx configuration:
Starting nginx.
Performing sanity check on php-fpm configuration:
Starting php_fpm.
Starting mysql.
SQL Temp Password: wpA,CdJffhcd
mysql: [Warning] Using a password on the command line interface can be insecure.
Using NAT Address: 10.10.0.100
The process control (PCNTL) extensions are required in case you want to interrupt long running commands - see http://php.net/manual/en/book.pcntl.php
Nextcloud was successfully installed
System config value trusted_domains => 1 set to string 10.10.0.100
chown: /usr/local/www/nextcloud/app-pkgs: No such file or directory
Stopping php_fpm.
Waiting for PIDS: 63502.
Starting php_fpm.
Stopping nginx.
Waiting for PIDS: 63479.
Starting nginx.
Admin Portal:
Hayama
Hello everyone,
0 => array(
‘writable’ => true,
i meet the same problem as yours
I had taken below actions this morning:
1. Remove the nextcloud and re-install
2. Remove the FreeNAS and install the TrueNAS
3. Remove the Google Chrome and install FireFox
and the nextcloud still fault…
I feel a little hopeless and re-installing back the FreeNAS now as I found that TrueNAS hadn’t BT’s plug-in
jpatel
From Post Install notes, I can see below error
This directory "app-pkgs" doesn't exist. It looks like it is a typo in directory name. It should be "apps-pkg" and not "app-pkgs". I can see apps-pkg directory in that location. I think this might be causing the issue.
If developers of the plugins are watching this, can you please fix the typo and publish it?
danila_94
Doesn't help
Also from Nextcloud.
Looks like that is an issue from the Nextcloud side
Hello, luckily your not alone. Since a week i looking for a solution. Nothing helped yet... Only the case for the Nextcloud plugin. Hopefully somebody can help us.
Stay strong ^^
rasalone
If this is a dev error for the official plug-in is this something I should try and figure out how to file a bug report? I'm new to freenas but love the community and culture and freebsd. I finally finished building my system up around freenas for home everything! Thanks for the help.
Just reinstalled FreeNas and again same Error. With TrueNAS and FreeNAS. i hope we will find the solution together.
danila_94
I try to rename, doesn't help :(((
remear
I seem to have fixed my fresh NextCloud plugin installation. Here's what I observed and fixed along the way.
I experienced the too many redirects error when attempting to load /apps/files post sign-in.
jexec'd into the jail. /usr/local/www/nextcloud/apps is empty. Apps seem to be located in /usr/local/www/nextcloud/apps-pkg.
Moveed the apps directory to where the nextcloud config default expects them to be located. cd /usr/local/www/nextcloud && mv apps apps-old && mv apps-pkg apps
Fixed logging by appending 'logfile' => '/var/log/nextcloud/nextcloud.log', to the config array in /usr/local/www/nextcloud/config/config.php
Restarted php-fpm and tried again. service php-fpm restart.
/var/log/nextcloud/nextcloud.log` complained with errors like `Base table or view not found: 1146 Table 'nextcloud.oc_flow_operations' doesn't exist.
Edited /usr/local/www/nextcloud/config/config.php and set 'installed' => false. Went to the base URL again (no /apps/files), and got to the installation screen so I could have it "re-do" the installation. Entered in the same DB connection info from the post-install details. Added info for a new admin user (not ncadmin, because it already exists). Submitted the form and let it complete.
Hayama
You’re right so I just reported to jira.ixsystems.com
Hoping you both could also send your bugs report to them or find other channel to reports the problem.
jpatel
Thanks for reporting a bug. I believe here is the one you created. https://jira.ixsystems.com/browse/NAS-108785. Just thought to post a link so others can add the comment in the ticket so developers can know it's a blocking bug and set the priority accordingly.
rasalone
Thanks for posting the jira ticket. I watched and voted as well as added comment do you need more people to vote for it to get it looked at?
