NextCloud plugin seems to have an issue, after configuration, it gives the ERR_TOO_MANY_REDIRECTS error. So should it be reported here or to NextCloud?
Using the following command fixed it but it is now saying something about integrity. So need to figure that one. At least I am able to get to the site.
cd /usr/local/www/nextcloud
su -m www -c “php ./occ config:import < /usr/local/share/nextcloud/fix-apps_paths.json”
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
