I'm using TrueNAS 12.0-U4 as a fresh installation. Active Directory works upon initial setup and rebooting TrueNAS, but changes to "FAULTED" after a new SMB share is created. I've tried a clean install three time to replicate this each time.
The steps I'm taking after a clean installation:
wbinfo errors out with:
log.smbd has this notable error:
- System -> Timezone -> set to America/New_York
- Network -> Global Configuration -> set hostname and domain
- Hostname is just the name of the computer account in AD
- Domain name is the full FQDN of my domain
- Directory services
- Set domain name
- Enable verbose logging
- Enable allow trusted domains
- Change NetBIOS name to match hostname
- Join domain
- Domain joining is successful, and results are returned for the command "wbinfo -u"
- Create new storage pool (set to "SMB" instead of "generic"
- Create new dataset
- Used ACL preset "RESTRICTED" and made no changes
- Reboot TrueNAS
could not obtain winbind interface details: WBC_ERR_WINBIND_NOT_AVAILABLE
could not obtain winbind domain name!
Error looking up domain users
create_local_token_failed: NT_STATUS_INVALID_PARAMETER_MIX
ERROR: failed to setup guest info.
From what I'm gathering, Samba is not launching due to a fatal error - specifically, the inability to access a guest or admin account on my active directory. Is there a workaround for this issue? Unfortunately, this is a larger enterprise active directory, so I'm not able to create guest/admin accounts on this AD for TrueNAS - I can only use my account to join the domain.
I took a look at: [URL]https://www.truenas.com/community/threads/smb-service-failed-to-start-after-upgrading-to-11-2-from-11-0-stable.77121/[/URL]
But in my case I do not have any linese referencing a guest account in the results of "testparm -s"
Thanks for the insight!
