nielsd
- Apr 22, 2022
Hi all,
old PDC + AD
we have a Samba PDC ("server") with AD (managed by Windows RSAT) with Roaming Profiles on a old "FreeNAS 10".
The "server" config
Joined a second / new PDC+ AD
I've added a new redundant Samba PDC with AD ("pdc2") to the Domain just by join which syncs fine with the old Samba PDC / AD and providing the same Unix UIDs/GIDs:
The PDC2 config (as default / auto created by samba init):
Join new TrueNAS as NAS (only reads users/groups from AD)
but when i try to attach a new TrueNAS system - it should provide Samba shares - i'm unable to "match" the Unix UID/GID idmap-ping in any way (while TrueNAS persist to set idmaps in the config):
I tried to play with RID as AUTORID but did not provide consistent UID/GIDs.
How can i caclulate the correct RID? The official docs are very diffuse to me how to get and calculate the correct ranges.
Or does Any other IDMAP mech suits here better?
TrueNAS (nas3) should only provide NAS shares (from ZFS) with the Users/Groups from AD without any local/own user management.
many thanks,
niels.
old PDC + AD
[root@server] ~# wbinfo -i "SRG2\niels" SRG2\niels:*:3000187:20:
The "server" config
[global]
server min protocol = CORE
server max protocol = SMB3
encrypt passwords = yes
dns proxy = no
strict locking = no
oplocks = yes
deadtime = 15
max log size = 51200
max open files = 941843
logging = file
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
getwd cache = yes
guest account = nobody
map to guest = Bad User
obey pam restrictions = yes
directory name cache size = 0
kernel change notify = no
server string = SRG Server (neu)
ea support = yes
store dos attributes = yes
lm announce = yes
time server = yes
null passwords = yes
acl allow execute always = true
dos filemode = yes
multicast dns register = yes
domain logons = yes
local master = yes
idmap config *: backend = tdb
idmap config *: range = 1000-100000000
server role = active directory domain controller
netbios name = SERVER
workgroup = SRG2
realm = SRG2.LOCAL
dns forwarder = 192.168.123.254
idmap_ldb:use rfc2307 = yes
create mask = 0660
directory mask = 0770
client ntlmv2 auth = yes
dos charset = CP437
unix charset = UTF-8
log level = 2
tls enabled = yes
tls keyfile = tls/key.pem
tls certfile = tls/cert.pem
tls cafile = tls/ca.pem
logon path = \\%L\profiles\%U
logon drive = L:
preexec = /mnt/pool/admin_tools/sbin/netlogon_create %U
nsupdate command = samba_dnsupdate
wins support = yes
unix extensions = no
[sysvol]
path = /var/db/samba4/sysvol
read only = no
vfs objects = zfs_space zfsacl
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
zfsacl:acesort = dontcare
[netlogon]
path = /var/db/samba4/sysvol/srg2.local/scripts
read only = no
nfs4:mode = special
nfs4:acedup = merge
nfs4:chown = true
[antivir]
path = ...
root@pdc2:~ # wbinfo -i "SRG2\niels" SRG2\niels:*:3000187:20:
root@pdc2:~ # cat /usr/local/etc/smb4.conf
# Global parameters
[global]
netbios name = PDC2
realm = SRG2.LOCAL
workgroup = SRG2
### added by me
wins support = yes
# allow enumeration of winbind users and groups
winbind enum users = yes
winbind enum groups = yes
### end
[sysvol]
read only = No
[netlogon]
read only = No
root@nas3:~ # wbinfo -i "SRG2\niels" wbinfo -i "SRG2\niels" SRG2\niels:*:1001333:1000513::
many thanks,
niels.
