I'm trying to enable serial console for the SOL on a SuperMicro X10SL7-F using the FreeNAS gui. I'm selecting 0x3e8 as serial port address and checking use serial console. On saving the following warning appears in /var/log/messages:
Requested serial terminal but GRUB_SERIAL_COMMAND is unspecified. Default parameters will be used.
/boot/grub/grub.cfg contains the following configuration:
serial
terminal_output console serial
set timeout=5
I do get serial output through the bios, disk, pxe and the grub menu screens. After the grub menu there's no output. This is on a fresh 9.3 release install with settings imported from a 9.2.1.9 system.
serial
set timeout=5
